Sponsored by: Auxito
transfer case oil
Old Nov 3, 2004 | 04:55 PM
scar98's Avatar
scar98
transfer case oil
I have a 1999 F150 xlt sc 4x4.How often do you need to change the transfer case oil.It has 162,ooo km
Old Nov 3, 2004 | 08:44 PM
Racerguy's Avatar
Racerguy
I think that Ford recommends 100K km.
When in doubt change it out
Old Nov 3, 2004 | 10:04 PM
superrangerman2002's Avatar
superrangerman2002
If you are going to change it out, I reccomend two things:
1. The lip on the cross member will cause the fluid to spray all over, it really creates a huge mess when you pull the drain plug. I would modify a large funnel to keep that from happening.
2. I reccomend using a Mobil 1 synthetic ATF in the T-case.
I thought that the T-case had a 100K "mi" change interval , and not "km"?
Old Nov 3, 2004 | 11:21 PM
Racerguy's Avatar
Racerguy
For severe conditions they recommend 60,000 miles.
Where I live we usually go by the severe conditions recommendations.
Good tip about the mess it makes.
Old Nov 3, 2004 | 11:42 PM
superrangerman2002
Learned that tip the hard way...
I must have the t-case confused with something else...
Old Nov 4, 2004 | 12:07 AM
scar98's Avatar
scar98
T-case
Thanks for your advice fellows.I'll change it on the weekend.
jdhudall
1997 - 2003 F150
Mar 28, 2013 06:59 PM
cowmilker08
Nov 6, 2008 05:36 PM
six6plymouth
Feb 24, 2005 11:46 AM
farmerjoe
Dec 28, 2004 08:02 PM
Jerry Van Winkle
Oil & Lubrication
Aug 3, 2004 03:47 PM
