Rear end fluid change
Old Nov 3, 2004 | 02:55 PM
mike L's Avatar
mike L
How often should the rear end fluid be changed? 100,000 miles?
Old Nov 3, 2004 | 03:04 PM
cmoore99's Avatar
cmoore99
I did mine at 100,000 miles. I check it every 10,000 or so and top it off. It usually takes a few ounces to top off.
Old Nov 3, 2004 | 04:19 PM
t_dickie's Avatar
t_dickie
100,000 miles sounds good. Remember if you have a posi (limited slip) you need to put in some friction modifier. I think any type will work.
Trevor
Old Nov 3, 2004 | 05:42 PM
ford4.9's Avatar
ford4.9
service book that i have says ever 24000 miles or if the rear end is under water at anytime to do so as soon as one can. i bet you can go to 50000 with a synthetic, yet do it ever 8 oil changes what can it hurt it is cheap.
Old Nov 3, 2004 | 05:45 PM
ford4.9's Avatar
ford4.9
oh ya don't forget to checkout rear end seals when you change the hypoid gear oil.
