Bronco II Ford Bronco II
suspention????
Old Nov 2, 2004 | 10:38 PM
ohioredneck's Avatar
ohioredneck
Question suspention????
hello all new guy here this fourm is alsome helped me a lot so far. i just had a question on the suspention i read about the swap u can do with a explore i was wondering should i buy shocks for a explore or bii??? and anyone who has replaced the heads how did it go and where do i get a new pair?? got a tight budget. any help would be great. by the way 88 bii 4.9 4x4 5-speed. and how far can i lift with out having to changeing the drive shaft,and no body lift. i heard 2in is the max is that true. thanx ohioredneck
Old Nov 3, 2004 | 02:39 AM
RomerB2's Avatar
RomerB2
If you swap in coils and leaf springs from the explorer, you're driveshaft should be fine, I've heard up to 4" lift on the driveshaft question. The Explorer springs will lift you about 2-2.5". When it comes to the heads, go with world products.
You can get to them here: http://worldcastings.com/
Old Nov 3, 2004 | 04:00 PM
ohioredneck
what about
what about the shocks? do i get bii or explore shocks?
Old Nov 3, 2004 | 04:39 PM
ohioredneck
tires
ok thanks man if i do the explore lift can i fit 31 10.5's on there with no rubing and no bottoming out? i want to go muddin
Old Nov 4, 2004 | 12:17 AM
RomerB2's Avatar
RomerB2
I have 31's on mine right now, if you look in my gallery those are 265 75 15's which is basically .5" shorter than the 31's and the 31's are a little wider, and I've had no rubbage at all, and I've done a little offroading, nothing to big, but I've gone over quite a few deep bumps going about 35 and I haven't bottomed out, and I also don't have a lift of any sort on mine.
