71 C6 Modulator
Old Nov 2, 2004 | 03:15 PM
Bookman's Avatar
Bookman
71 C6 Modulator
Is this a difficult job to change this out or any special watch out for this type of things in changing it out????
Old Nov 2, 2004 | 09:09 PM
rclarke's Avatar
rclarke
Easy part to change, be careful not to lose the rod between the modulator and the valve inside it usually will come out with the modulator and is easy to lose if you aren't aware of it. You will lose a little oil so expect it. If you jack up the rear of the vehicle you will minimize the oil spill.
