Time required to replace starter?
Old Nov 2, 2004 | 11:45 AM
dan1101's Avatar
dan1101
Went to vote this morning but my truck didn't want to leave the firehouse parking lot. Just went "click" when I turned the key. I already had this problem once, fixed it by replacing the battery terminals. This time I cleaned the terminals, and tried a new starter relay, no luck. Next I'm gonna get up under it and check the starter connections, but worst case how long am I gonna need to replace the starter? I'm trying to figure out whether to replace it were it sits or try to get it back home somehow first.
Old Nov 2, 2004 | 11:59 AM
rebel_ford4x4's Avatar
rebel_ford4x4
i cant give you a time in minutes but it doesnt take very long at all. theres just 2 bolts holding it in and a couple wires you have to unplug. its very easy and pretty quick to do.
Old Nov 2, 2004 | 12:08 PM
dan1101's Avatar
dan1101
That's what I figured. Might take me twice as long as you, but still doesn't sound bad. Thanks for the info.
Old Nov 2, 2004 | 01:07 PM
guzzler96's Avatar
guzzler96
Post
Should probably be 30 mins. or less, depending on how many digits get bumped or mashed.
Old Nov 2, 2004 | 01:28 PM
ASH's Avatar
ASH
Good estimate assuming you don't twist the bolts off that hold the starter in place. Might want to hit them with some penetrating fluid. Also, don't overtighten the brass bolt that the wires are connected to. I did this and twisted off the lug. Finally got the wire back on the stump that was left, but blew quite a bit of time.
Old Nov 2, 2004 | 05:03 PM
dan1101's Avatar
dan1101
Well, turns out it was the small wire going to the spade connector on the starter. The insulation is all cracked and falling off, and the spade was not rusty but was dirty. No wonder, why put a spade connector up under the vehicle on a critical part? I cleaned the connector with WD40 and wiped the spade off, and it cranked just fine.
I'll probably redo all that wiring the right way so my truck don't strand me any more.
Old Nov 3, 2004 | 04:16 AM
Bassgetter's Avatar
Bassgetter
Glad you figured that out. My truck did the exact same thing and I went through the exact same routine as you. Wiggled the starter wires and haven't had a problem since. Those are the fixes I like.
AtlM5
Dec 13, 2015 07:57 PM
Island Time
Electrical Systems/Wiring
Aug 16, 2014 05:59 PM
Singing River Farm
18
Jan 25, 2014 03:51 PM
hypophthalmus
Aug 22, 2012 10:19 PM
