Sponsored by: Real Truck
Diffrence between F250 and F350
Old Nov 2, 2004 | 09:18 AM
SoundBuys's Avatar
SoundBuys
So what is the real diffrence between an PSD F250 and F350? I have a 2000 PSD F250 and I was looking to see if I would be able to increase the payload of the F250. I currently pull a trailier with my race car on it (open trailer) but I am looking to upgrade to a Gooseneck or 5th wheel enclosed trailer.
I know that the blocks are diffrent in the rear, some say that is all so that is what I am wanting to find out.
Old Nov 2, 2004 | 09:21 AM
johnsdiesel's Avatar
johnsdiesel
The blocks are the only real difference. Check out the email from Ford in the FAQ. That being said, there is no legal way to increase your payload. If you swapped out the rear blocks with F350 blocks it would help rear end sag though.
Old Nov 2, 2004 | 09:59 AM
SoundBuys's Avatar
SoundBuys
so if I swap the blocks it will help with sag.... ok I get that. But if that is the only diff is that not increasing the payload?
Also where can I get blocks from?
Old Nov 2, 2004 | 01:55 PM
jake00's Avatar
jake00
it will increase the payload, but not "legally" as in your door tag would still read the same
Old Nov 2, 2004 | 03:03 PM
jwdeats's Avatar
jwdeats
You could get an F350 driver side door to go with those F350 blocks.
Old Nov 2, 2004 | 03:04 PM
Autobahn F-250 Lariat's Avatar
Old Nov 2, 2004 | 03:41 PM
SoundBuys's Avatar
SoundBuys
Talking
I see what everyone is saying.....
Old Nov 2, 2004 | 03:42 PM
Crash687's Avatar
Crash687
don't forget, the tires come larger stock from the factory.
Old Nov 2, 2004 | 05:35 PM
The Bull's Avatar
The Bull
I looked but couldnt find that email from Ford. Any help?
Old Nov 2, 2004 | 05:40 PM
Sparky04SD's Avatar
Sparky04SD
Actually, 04 F250's come with same size as 04 F350 versions. 04 250XL's came with 235's but XLT and Lariat's came with 265's standard. Pretty sure that's true of the 2000 models that Soundbuys was talking about.
Old Nov 2, 2004 | 05:42 PM
The Bull's Avatar
The Bull
Umm, damn, after reading that makes me think I wasted my $$ on a 350.
Old Nov 3, 2004 | 09:12 AM
Edmo's Avatar
Edmo
Not always true...
My 2001 F-250 came stock from the factory with the 10 ply load range E tires... Same as on the the 350. As I looked at the vehicles on the lot when buying mine, all of the 250s & 350s at this dealer had the bigger tires.
Edmo
Old Nov 3, 2004 | 05:51 PM
82F100SWB's Avatar
82F100SWB
Yup, 265 load range E's on my 00 out of the box.
Old Nov 4, 2004 | 08:56 AM
Mbmaring's Avatar
Mbmaring
I hope I understand the question but the f250 and the f350 have totally different front ends I think. I have a f250 that has that goofy independent front axle and my f350 has a good old rigid straight axle in the front. I like the straight axle as varying loads will ruin front tires on a independent axle.
Old Nov 4, 2004 | 10:49 AM
Yeti's Avatar
Yeti
Your talking pre 99 were talking 99 and up....
