Intake / PVC
Old Nov 2, 2004 | 09:11 AM
rmilchman's Avatar
rmilchman
Intake / PVC
A couple of years ago I bought an intake kit that had a "chrome" pipe. After two years the chrome doesn't look to good and it has spots on the inside. I want to replace it before it causes damage, and I was thinking about using plastic PVC pipe (white). Do you think the pipe could take the heat from the engine compartment?
Rich
Old Nov 2, 2004 | 09:12 AM
johnsdiesel's Avatar
johnsdiesel
I know some have done it, but I wouldn't recommend using PVC pipe. Why not use exhaust tubing?
Old Nov 2, 2004 | 09:41 AM
Kwikkordead's Avatar
Kwikkordead
Not to argue here, but I would never have any qualms about using PVC. Am I ignorant of a problem with it? Can't take the heat under the hood or something? Chemical/petroleum intolorance?
Old Nov 2, 2004 | 12:03 PM
444dieselrod's Avatar
444dieselrod
Check out my gallery I have a big hunk of pvc for my intake, so far I haven't had any problems with it and its been there almost 10,000 miles.
as far as a chemical problem kwik. look at the glue you use to hold it together, that doesn't eat it up, and the stuff is used for sewer piping and it will tolerate that, so I would think that the only problem it might have would be a heat issue from the engine, and so far i haven't had any with mine.
Diesel rod
Old Nov 2, 2004 | 12:56 PM
rmilchman's Avatar
rmilchman
I thought about exhaust pipe, but it's a lot more expense then PVC and probably harder to find in the diameter I would need.
Old Nov 2, 2004 | 01:48 PM
mjwhip2's Avatar
mjwhip2
I went to a place called six states and got a piece of 45degree 4" exhaust. Cost around $20. Looks decent and don't have to worry about anything. I had a hard time finding a piece of pvc without a flare on one side. Granted, if I were more patient I could have found a piece but I had my massive filter at home and wanted it on the truck.
As far as being hard to find, any exhaust outfit will have or could point you in the right direction into where you can get the tubing.
Mike
Old Nov 2, 2004 | 06:54 PM
johnsdiesel
I would be hesitant to use PVC simply because I'm not sure how it would handle the heat in the longrun under the hood. Also, I know for sure exhaust tubing can handle the heat. It may work fine, but why bother when you can get a piece of exhaust tubing for a relatively little amount of money.
Old Nov 3, 2004 | 11:44 PM
slapage's Avatar
slapage
The inside diameter of the exhaust pipe would be larger then a piece of pvc which means better flow. My exhaust came with an extra piece of 4" stainless that I used, I still have some left over but its straight not 45
Old Nov 4, 2004 | 07:01 AM
blackf3504dr's Avatar
blackf3504dr
I do know that schedule 40 PVC waste pipe is not rated for hot water , but I'm not sure it couldn't stand under hood temps . As long as some of ya are already running this setup maybe you could keep tabs on it and report back as to how the PVC is holding up .
Old Nov 4, 2004 | 07:57 AM
rmilchman's Avatar
rmilchman
I'll have to measure what size pipe I currently have, it's straight and has no bends.
Old Nov 4, 2004 | 08:43 PM
Domino'sDiesel's Avatar
Domino'sDiesel
DWV pvc would work fine. Heat shouldn't be an issue, just stay away from the abs pipe (black) That stuff melts fairly easy and become brittle after it is weathered. Finding the correct size tubing might be a problem in pvc, the outside diameter of 4" is about 4 5/8". Another option maybe 4" copper check a local supply house see if they have a short peice and 45*
Old Nov 4, 2004 | 09:00 PM
rmilchman's Avatar
rmilchman
If you look in my gallary (https://www.ford-trucks.com/user_gal...=14503&width=0) it's a straight piece of tube, no bend.
Old Nov 4, 2004 | 09:17 PM
fordnut74's Avatar
fordnut74
I had to do some custom intake plumbing on my 66 Jeep when I put the EFI 351 in it and used various bits of PVC. This was about 7 yrs and many thousand hard miles ago and It is still holding up just fine.
styleside96
1997 - 2003 F150
Aug 6, 2012 05:59 PM
pinger
1983 - 2012 Ranger & B-Series
May 3, 2010 01:23 PM
fordtrucklover94
Sep 17, 2004 12:44 PM
69crewcab
19
May 5, 2004 09:59 PM
plugugly
15
Jan 3, 2003 09:14 AM
