Homemade Intake for 97 PSD
Group
i know this was talked about before, but i want to build a homemade
intake, i have the filter like the napa 6637( i think thats the #)
ANd read about using PVC for the pipe.. I tired 4" Pvc and its was to Big
but a 3" 45 degree elbow that 4" OD and that seems like its too much for the
filter too...
I really want to build my own then go aftermarket..
What can i do
filter too...
What can i do
I did mine with a piece of 4" exhuast pipe cut about 6" long, the fliter rests on the inner fender in front of the master cylinder and behind the driver side battery.
Works fine until I get the TYMAR intake kit.
I did buy a constant torque clamp for the filter-to-pipe joint, the hose for the factory air filter attaches to the other end of the pipe.
If you want a little better "set" to the filter get a 45 degree bend exhaust pipe.
If you look at the inside diameter of the exhaust pipe vs. the inside diamater of the PVC you will see the exhaust is a lot bigger.
Dave / Believer45
Dave / Believer45
on
duck,
i am also in process of building my intake. napa filter number is 6637. everyone seems to say that this filter has the same duralite sticker as the donaldson. also you can get the orange silicone intake boot to connect 4" exhaust pipe to the factory intake part # 1743 it 6" long 4" diameter they also have an eight inch but i have not received it yet to know if it will work. also have a 4" 45 degree pipe coming that is about 12" long. i may have to cut it down. i still have checked into a clamp to hold the filter off the fender. where did you get your constant torque clamps and what did they cost?
good luck on your performance
tjbeggs
tjbeggs
on
believer45 i was thinking thats what your name mean and was hoping you would tell me that. i too am a believer. good to meet you.
tjbeggs is simply my name tim beggs.
schmeder, the orange silicone hose i got from napa part # 1743 is a direct replacement for the one right before the turbo. i am using it between my exhuast pipe elbow for my home made intake and the factory aluminum tube where the breather goes into the intake tubes. napa has a 6" and an 8" not sure if those would fit or maybe you could cut one down?
tjbeggs
tjbeggs
on
Originally Posted by schmeder
tjbeggs
Tryed that number from Napa came up with united wheel cyl repar kit rear. maybe there is a prefix? . As for the clamps the constant torque can be a clampco # 94143-0450 or ideal 300300456 or breeze size118. I would appricate the help thanks
thanks for the clamp numbers
tjbeggs
69crewcab,
Fortunately I have a whole mess of it laying on my property. But I'm certain there is a farmer somewhere around you that might have some smashed or bent irrigation pipe. You can usually get enough pipe to make your intake piece. And you can polish the aluminum. Good luck and sorry it took me so long to get back guys. TJ your question was answered before I got back, sorry.
RubberDuck
RubberDuck
