2bbl to 4bbl linkage coversion
Old Nov 1, 2004 | 09:55 PM
ford390gashog's Avatar
ford390gashog
i wanted to know what type of accelerator linkage you went to when you went to a aftermarket 4bbl carb i know the stock ones snap onto the carb but the holley i bought just has different holes drilled this is in a 75 with a 390
Old Nov 1, 2004 | 11:25 PM
tellico racing's Avatar
tellico racing
You may be able to unscrew the stud off the old carb and use it on the holley. If that won't work, the linkage studs are available at most auto parts stores.
Old Nov 1, 2004 | 11:26 PM
77460f150's Avatar
77460f150
You can get the "ball socket" with threads on the end so you can bolt it in one of those holes on your new holley. I got a couple from the scrap yard, and I think you can get these at a Napa store as well. -Ed
Old Nov 3, 2004 | 03:03 AM
docholiday72tx's Avatar
docholiday72tx
Ford390gas hog, I had a 75 model truck for a while that had a 390. I bought a Holley 600 for it. That carberator had the holes like what you describe. I had to buy a ball stud at the auto parts store that went through one of the holes to hook it up. Let me know if you have any more questions. I still have the carb and I have a digital camera. I can get pictures if you need them.
