Modular V10 (6.8l)
V-10 Engine Block Heater
Old Nov 3, 2004 | 03:38 PM
Studenut65's Avatar
Studenut65
2000silverbullet,
I live here in PA and yes, we do contend with the salt on the roads. This past summer, the frame was driving me nuts. It looked bad compared to the rest of the truck. It was dirty and had surface rust. What I did was wire brush and spray paint the frame. It looks good and will help aid against the salt. I'm more worried about my aluminum wheels...haha.
Old Nov 3, 2004 | 05:36 PM
2000silverbullet's Avatar
2000silverbullet
Thanks for the info. I've read some other posts about some coating you can paint on so someday I plan on coatin' the whole underside of my truck (as much as I can)
Crap, now I gotta worry about my rims???? aye carumba.....
Old Nov 21, 2004 | 09:59 PM
birddog16's Avatar
birddog16
I have a 03 F350 V10 FX4, Not sure if it has a block heater or not but would like to check and see where do they hide the plug in for those?
Old Nov 22, 2004 | 08:52 AM
Studenut65's Avatar
Studenut65
birddog16,
My engine block heater plug is right behind my front bumper on the rubber guard that is under the radiator area. Check there with a flashlight, I'm sure you'll find it. You should be able to trace the plug wires back to the side of the block where the heater is located. Good luck.
Old Nov 22, 2004 | 08:55 AM
Brad99SD's Avatar
Brad99SD
Mine is right under the driver side tow hook. If you stick your hand threw under the hook it may be laying in the bumper. good luck
Old Nov 22, 2004 | 09:42 AM
2000silverbullet
Any idea how much the dealer would charge to put one in? Or am I better off doin' this on my own? Any recommendations/links to aftermarket heaters?
Old Nov 22, 2004 | 10:18 AM
birddog16's Avatar
birddog16
thanks guys but it looks like mine does not have one, the only thing I could find was the wiring for the fog lights and 2 lines for the trans cooler.
Jacob Lowell
Jan 18, 2017 01:05 PM
David Fehir
Jan 22, 2016 05:25 PM
comsupany
17
Oct 25, 2015 12:19 PM
prmac
1983 - 2012 Ranger & B-Series
Jan 4, 2006 05:30 PM
Quinny
Nov 2, 2005 08:42 AM
