4.0l rebuild ????
Old Nov 1, 2004 | 12:46 AM
sitzerland's Avatar
sitzerland
4.0l rebuild ????
Okay I have killed my 4.0 hydro-locked the engine in a river crossing in wyoming while elk hunting. Heres my question my 1993 ranger 4.0l needs rebuilding last rebuild 45,000 miles ago took the engine to .75mm oversized. My question is will the 4.0 block hold up to going 1.0mm over or should i find a donor block and start back over. I am running world heads that are 50% thicker in decks and ports so i know they will take the abuse but will the block and gaskets hold up if we go 1.0mm over seems like a strech on this engine.
Old Nov 6, 2004 | 12:57 PM
Rockledge's Avatar
Rockledge
You might pick up some tips here:
http://www.babcox.com/editorial/ar/ar40123.htm
