302 buildup
302 buildup
I picked up a 79 F100 from Texas. 302/c6 combo. This is gonna be my playtoy.. heres where im startin with the motor ..
Holley 650
Edelbrock Performer RPM Intake
Comp Cams Cam (Lift: .509''/.512'' Duration: 268°/280° RPM Range: 1600- 5800)
Mild port/polish on the heads
Comp Cams Valvesprings-retainers
LT headers
Not tearin the shortblock apart. Rods and mains are in good shape with still decent compression on all cylinders.
Also a 2400 stall conv. and B&M Shiftkit in the tranny
Somebody wanna plug that into desktop dyno and see what comes out??
Thoughts? Suggestions?
I'll pull the Shortblock apart the end of summer (2007) and change the pistons, bore/stroke etc etc
Holley 650
LT headers
Do a head swap. Any thing's better than those 70 cc chambered boat anchors it's got. A set of E7's with the exhaust ports opened up and the bowls blended would be a good cheap choice. Do the cam some good to raise the comp ratio with smaller chambers. Mill the E7's about .030 to ge the cc's down to about 60. That'll give you about a full point increase over the 78 heads.
fozzy
07-31-2008 10:16 AM
jade79
26
06-12-2008 06:25 PM
fordfan302
03-10-2008 08:25 PM
TxBandit
12-03-2001 12:32 PM
karljay
11-17-2001 09:22 AM
