03, 7.3PSD GPR location
Old Oct 31, 2004 | 04:50 PM
akdriver's Avatar
akdriver
Wondering where the GPR is located. looking at the passanger side there are 2 relays on the top of the motor is it one of these or both, or some where else. Also will a 02 or earlier GPR work none of the after market part stores show a listing for them yet.
Old Oct 31, 2004 | 05:32 PM
realhp's Avatar
realhp
Yes the relay closest to the back of the engine should be the GPR. The GPR wiring should go directly into the wiring harness and I believe they should be yellow and brown. The other relay in front should have a red wire going to the intake. I don’t know if a 02 GPR is the same as 03, I would think so as long as it is a 7.3.
Old Oct 31, 2004 | 06:39 PM
akdriver's Avatar
akdriver
OK Thanks, what is the other relay for?
Old Oct 31, 2004 | 06:52 PM
Kwikkordead's Avatar
Kwikkordead
The intake air heater element. Good for really cold climates.
Old Oct 31, 2004 | 07:15 PM
akdriver's Avatar
akdriver
Thanks
I just bought the truck a month ago and it's just starting to get cold here, it was 18* last night. I have been having to plug it in the last few mornings to get it to start so after searching the post's for a fix I thought I would start with the GPR.
When I purchaced the truck I did a car fax report and it was originally a Canadian truck, then sold to someone in Nebraska and a couple of months later sold at a auction and found its way here in Anchorage on the dealers lot.
So the air intake heater should be a help espically if I can get the current problem cured.
Not to thrilled with the prospect of replacing the GP's so I will have to test them first, hopefully the GPR will do the trick. Still cold enough outside to get your fingers cold quickly holding metal parts.
Old Oct 31, 2004 | 08:42 PM
realhp's Avatar
realhp
Have you checked your GPR with a test light?
Old Oct 31, 2004 | 08:58 PM
wlihntr's Avatar
wlihntr
Thanks
if you have not done so already changing to a full syn oil will help on the cold starts(mobil 1 delvac 5-40,mobil 1 truck and suv 5-40)...i bet it gets pretty cold up there
Old Nov 1, 2004 | 07:53 AM
akdriver's Avatar
akdriver
No I have not changed to Syn yet but may do so when it gets colder depending on how it starts (when it's fixed and colder) I do have a magnetic oil pan heater on it which will help here at home but not at work.
We finally are getting some snow here yesterday and today not much but a start.
Still wondering if anyone knows if a 02 GPR will work on an 03
Going to check with an international dealer for a GPR for a price compareson
Old Nov 1, 2004 | 06:51 PM
akdriver's Avatar
akdriver
I called the Ford dealer here they wanted $149.95 for a GPR. They sure are proud of them.
The International dealer wanted $25.63 ..........I guess they are not so proud of theirs.
So I guess I dont want to be so proud either.
Old Nov 2, 2004 | 09:14 AM
akdriver's Avatar
akdriver
Talking
Well it was 8* this morning I did not plug it in last nignt It fired right up with hardly any cranking
Thanks for your advise.
coreyallan01
Jan 6, 2015 10:36 AM
farmer ford
Dec 2, 2012 03:36 PM
maevans
22
Dec 9, 2009 07:10 PM
ngng
Mar 17, 2009 08:13 PM
powerstrokeddiesel
Aug 23, 2007 07:17 PM
