Erratic idle still
Old Oct 31, 2004 | 07:57 AM
eb4tx's Avatar
eb4tx
Erratic idle still
Hey gang...my daughter's 2001 Explorer Sport has a persistent rough idle. When cold, like when sitting overnight, startup idle is very erratic and engine usually dies. After a few restarts engine will run smooth. Once engine is warmed up no idle problems at all. A month ago her check engine light came on. Had a scan done a local Ford dealership and scan indicated a faulty MAF sensor. Checked this forum and did the recommended maf sensor remove and cleaned w/electrical contact cleaner and reinstalled. Same problem. 2 or 3 weeks later check engine light came on again. Had scan done a local Auto Zone. Scan indicated:lean engine-bank one, lean engine-bank two. So checked forum again and found the IAC repair and removed and cleaned IAC. Same problem. At this point, I had to make a decision as my daughter was getting ready to drive from Texas to her new job in Port St. Lucie, Florida. So I went and bought from my local Ford dealer a new MAF sensor and new IAC valve. Installed both and you guessed it, same rough idle at cold startup. And thoughts out there on cause of rough idle when cold?
Old Nov 1, 2004 | 10:40 PM
billm506's Avatar
billm506
I am having the same problem. Let me know if you get the problem resolved. Thanks
billm506@yahoo.com
Old Nov 1, 2004 | 11:10 PM
ltfox's Avatar
ltfox
On my 2000 w/4.0 SOHC I had the same problem. Dealer kept looking at the Map sensor and I changed the IAC. Ended up being the lower intake orings. Basicaly a vacume leak. Letting air into the engine that the computer wasen't reading thus the lean mixture codes. I changed the upper orings. But no change. Had a local mech do the lower ones and it did the trick. Not expensive at all if you don't count the labor for the lower ones. I think 10 bucks for the 8 orings.
Old Nov 2, 2004 | 08:19 AM
pax's Avatar
pax
"Not expensive at all if you don't count the labor for the lower ones"
I like this one. I feel better now. Since the lower intake gasket on my van is leaking coolant, to replace it, it is only a few dollars, if you don't count the labor.
Old Nov 2, 2004 | 06:54 PM
eb4tx's Avatar
eb4tx
Upper and lower o-rings on the intake? Do you mean the o-rings on the fuel injectors? Please clarify. Thanks.
Old Nov 3, 2004 | 12:06 AM
ltfox's Avatar
ltfox
The upper orings are between the plastic intake box (where your IAC sits) and the plastic intake manifold. The lower ones are under the manifold. Not an any injectors. The upper ones are two larger orings and I belive that the lower ones are eight smaller orings. I replaced the upper ones myself. Not to hard of a job but the lower ones did'nt look fun so I had a local mech replace them.
Old Nov 3, 2004 | 07:50 AM
eb4tx's Avatar
eb4tx
Thanks ltfox!
TwoMuchMud
Escape & Escape Hybrid
17
Jul 30, 2016 08:10 AM
mtnlovrs
General Automotive Discussion
Jan 17, 2010 01:41 PM
dr.ron
3.8 & 4.2L V6
May 10, 2009 09:11 PM
50th ann
1997 - 2003 F150
Jun 23, 2008 03:54 AM
jexplorer
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Dec 3, 2006 10:57 AM
