Preditor will not load after new Flash
Old Oct 30, 2004 | 08:00 PM
Katoum's Avatar
Katoum
Had my PCM flashed as per SSM 17048 from old cal 3u7aftc to new cal 3u7afte and now it will not allow preditor upload a tune, just give's a error message. Just wanted you all to be aware of this till I getted it sorted out with Diablo.
PS This is 04 6 litre
Old Oct 31, 2004 | 09:04 AM
04superduty's Avatar
04superduty
you probably need to up date your predator, which you can do online.
Old Oct 31, 2004 | 12:58 PM
SBV45's Avatar
SBV45
What version of the Predator are you using. You should see it as it boots up.
Old Oct 31, 2004 | 11:04 PM
resqdawg3's Avatar
resqdawg3
You did restore the factory tune back to the truck before you took it into the reflash, right?
Old Nov 1, 2004 | 09:36 AM
Katoum's Avatar
Katoum
The bootup reports this version.
v7r34f
Old Nov 1, 2004 | 09:56 AM
jdadamsjr's Avatar
jdadamsjr
Call Diablo @ 1-877-399-6417
and DO let us know what they do.... cuz I'm about to take mine in as well
Old Nov 1, 2004 | 05:31 PM
Katoum's Avatar
Katoum
I have been in touch with Diablo and they will get back to me in a few days maybe sooner!
It appears that the new flash from Ford is not compatible with the Diablo at this time. The files involved are VXAN04.HEX for the engine and TQAT0N7.HEX for the transmission. I guess I wait till I hear back from them.
Old Nov 1, 2004 | 09:46 PM
matt1751's Avatar
matt1751
I had a flash done on 10/18. Invoice shows states FICM,PCM,TCM--B33.8P3-- I just ordered a Predator on Friday. I hope it will work,, I've been wanting to get one for a few months now and I finally do it and watch it not work. Katoum, do you know what flash you have in you truck?
Old Nov 1, 2004 | 09:49 PM
Motown Fire's Avatar
Motown Fire
Is this flash a newer flash than the December 03 flash???
Old Nov 1, 2004 | 09:57 PM
matt1751's Avatar
matt1751
yes. my truck is a 1/21/04 build date and this is the 2nd flash its had since I bought it in March. Not sure how many actual update have been out since Dec 03 but I would say atleast 2. I just hope the latest one I got is older then what Katoum has. I really want to load my Predator when it arrives,, Getting Exhaust done on Wed. Gauges will be next project,,
Old Nov 1, 2004 | 11:43 PM
Katoum's Avatar
Katoum
Mine was flashed last week, please see my previous post for CAL numbers.
Old Nov 2, 2004 | 07:14 AM
matt1751's Avatar
matt1751
are you refering to the "VXAN04.HEX for the engine and TQAT0N7.HEX for the transmission you listed" as all my Flash showed was B33.8P3 so I don't know if there the same or not.. I e-mailed Diablo last night with my flash version to see what they say as well,,,
Old Nov 2, 2004 | 11:16 AM
matt1751's Avatar
matt1751
here is what I received from Diablo about this,, not much other then if it won't work they will have a update soon to fix it.
CATEGORY: Diesel
QUESTION: [I ordered a Predator on Friday for my 2004 F250 PSD 6.0. I just read
tonight that there is a problem with the Prefator not loading if you have the
newest flash from Ford. Is this true? I had a update from Ford on 10/18, invoice
stated FICM, PCM, TCM-B33.8P3 Will I be able to use the Predator with this
version? Thanks matt]
ANSWER:
Dear Matt ,
Make sure that the predator is on the most current revision (r34f). If your tool
does not work, an update will be out shortly to fix the issue.
Thank you for your interest in DiabloSport!
Stay tuned,
Dan, a proud member of the DiabloSport Support Team
Old Nov 2, 2004 | 11:22 AM
SBV45's Avatar
SBV45
Flashes for 03 and 04s are different. Katoum, from what you posted it looks like your engine is an 03. The flash you mention would be newer than the Dec 03 flash. Over on the flat rate tech forum there is no confirmation but rumblings there is a newer flash for the 03s. Your information seems to lend credibility to the flash rumors. How does your truck run? How is the mileage, better?
Old Nov 2, 2004 | 11:49 AM
jdadamsjr's Avatar
jdadamsjr
AARGGHHH...
I hope they don't flash it then...
just brought mine to the shop for the idle fix with EBP sensor....
not sure i could stand to drive my rig without the predator tune !!!!!
