Advancing Timing?
Old Oct 30, 2004 | 04:18 PM
RedStroker6's Avatar
RedStroker6
Advancing Timing?
i've been reading about advancing the timing to give a nudge more in horsepower. can someone give a better idea as to what it does and the like. i'm presuming it can be done to my '95, correct me if i'm wrong.
Old Oct 31, 2004 | 12:27 AM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Can you be more specific abut the mod you are considering? Your sig. lists the 10K mod, so you've already altered the injection timing some.
Old Oct 31, 2004 | 01:58 AM
RedStroker6
i've seen about the computer senses if the oil needs to be heated up more if its cold. it then feeds it a little more fuel or something to that effect. but if the 10K already meddles with the timing some, i probably should do anything more. i think i need to try re-seating the wires for that anyways, it isn't idling rough at all, so i'm not sure...might try to 5.6K resistor, unless that isn't a good idea....
TJaquatic
Jun 21, 2012 08:45 AM
lovethemud
Modular V10 (6.8l)
Apr 26, 2009 09:19 PM
TMI
27
Mar 19, 2005 07:36 PM
FghtinIrshNvrDie
Oct 21, 2004 12:19 AM
