98 Ranger Snow Plow Mount
Old Oct 29, 2004 | 09:19 PM
drummintruckit's Avatar
drummintruckit
Question 98 Ranger Snow Plow Mount
Hello,
First time poster here. Hope you guys can help I'm fabricating a snow plow mount for my 98 Ranger. I've heard it has to be made in such a way so to avoid the crumple zone area of the frame. Does anyone have any insight on this?
Thanks in advance!
Old Oct 29, 2004 | 10:53 PM
Higgin's Avatar
Higgin
I'm interested in this too. I have an old, smaller snowplow sitting at home that would be perfect for my 98 ranger. But i've never seen anyone with a snowplow on a newer ranger. If you go through with makeing the mounts, be sure to post back with some updates and specs and how it turned out.
Old Oct 30, 2004 | 03:24 AM
Help I M Stuck's Avatar
Help I M Stuck
try to find a pic of an actual mount that goes to your truck and take ideas from that.
Old Oct 30, 2004 | 12:23 PM
hreed's Avatar
hreed
I installed a Meyers plow on my 83 Ranger. The mounts were flat steel (about 3/16") that used existing holes in the frame. My guess is that if you use existing holes at the front of the frame and don't drill new ones, it should not be a problem. Also, try not to weld on the frame. If you must, only make the welds horizontal and no vertical welds. Use grade 8 bolts with nylon lock nuts. (Use the biggest you can fit into the existing holes).
Old Oct 30, 2004 | 06:01 PM
drummintruckit
Smile
Guys,
Thanks for the info! Help Im STuck, I found a snow plow mount on ebay. It's a pretty decent pic and gives some direction on how to make the mount. It pretty much looks like what you were talking about hreed...Thanks! Higgin check it out it may help you too. Thanks again.
http://cgi.ebay.com/ebaymotors/ws/eB...ayphotohosting
for some reason the link will only work if you remove all the info from the ford help site
Last edited by drummintruckit; Oct 30, 2004 at 06:05 PM. Reason: whoops forgot the link!
Shecky8
Jan 16, 2015 08:43 PM
Aquik72
Oct 27, 2011 05:22 PM
late70sfordnut
May 1, 2008 06:32 PM
EaTmYtAiLpIpEs
Aug 23, 2007 07:04 PM
black stallion93
Dec 2, 2004 08:11 PM
