replacing fuel filter in 2002 Ranger?
Old Oct 29, 2004 | 09:11 PM
dowlinga's Avatar
dowlinga
Anyone have a diagram and/or instructions on changing the fuel filter in a 2002 Ford Ranger 3.0L V6 5MOD? I have 45000 miles on it and want to replace the fuel filter, but have never done this before. There is no mention or diagram in the owners manual and I don't believe there is a Haynes out yet for the 2002 Ranger, is there? Anyway, if anyone has instructions or a diagram for replacing the fuel filter that they would like to share, I would really appreciate it.
Thanks! (oh...on the READ FIRST: Technical info forum page, there is a link for 2002 fuel filter replacement, but it actually links to an entirely different link about removing the door panel, so the answer isn't on that page, which is why Im asking now).
Old Oct 29, 2004 | 10:52 PM
knoxnil's Avatar
knoxnil
Go back to the Tech info page and look at the link for fuel filter change on 1999. I think it should apply to your 2002 also. GET THE TOOL!!! O'Reilly Auto Parts sells one for $7, a little red one.
Old Oct 30, 2004 | 12:14 PM
Ranger Lance's Avatar
Ranger Lance
Are you sure you need the tool? I have a 2000 3.0L and did not need a tool. After relieving the fuel system pressure: removed plastic "kick plate" on passenger right foot side, disconnected wire clip to fuel relay, started truck until it died, and then removed fuel cap.
Removed nut connecting fuel filter assembly to rail and "popped" off two clips on two of the lines to/from fuel filter (one on front one on back). On the other line on the back of the fuel filter just press on the bottom of the fitting with your finger or a small screwdriver and it will release and you can then pull the filter off.
You will need 2 new "clips" for the reinstallation of the new filter. The new filter does not come with them. Go to the help section of the auto parts store and look for Ford fuel filter clips or ask the counterperson.
I'm not saying you don't need the tools; just saying you might not. I bought the set at Autozone myself and then found out I didn't need them. The "procedure" for relieving the fuel system pressure was found in the owner's manual in the emergency section I believe where it says if you are in a wreck or fender bender and your truck will not restart to check the fuel relay by resetting the button on top (pressing it back in).
Old Oct 30, 2004 | 02:43 PM
Mike W's Avatar
Mike W
The manual for my 01 says to not use any tools. I haven't done mine yet. To tool or not to tool, that is the question.
Old Oct 30, 2004 | 03:22 PM
knoxnil's Avatar
knoxnil
See thar I go talking about something I know not about. I have a '99 and have to use the "tool" to release the lines off the filter, yes after relieving the fuel pressure. Maybe they've changed since then.
Old Oct 30, 2004 | 07:13 PM
Ken00's Avatar
Ken00
For my 2000....
Filter — Fuel
Removal and Installation
WARNING:
Do not smoke or carry lighted tobacco or open flame of any type when working on or near any fuel-related component. Highly flammable mixtures are always present and may be ignited, resulting in possible personal injury.
WARNING:
Fuel in the fuel system remains under high pressure even when the engine is not running. Before repairing or disconnecting any of the fuel lines or fuel system components, the fuel system pressure must be relieved to prevent accidental spraying of fuel, causing personal injury or a fire hazard.
1. Relieve the system pressure. For additional information, refer to «Section 310-00».
µ 2. Disconnect the push-connect and R-clip fittings. For additional information, refer to «Section 310-00».
µ 3. Remove the nut and the fuel filter.
4. To install, reverse the removal procedure.
Fittings — Push Connect
Disconnect
WARNING:
WARNING:
1. Relieve the fuel pressure. For additional information, refer to «Pressure Relief—Fuel» in this section.
µ 2. Separate the fitting.
1 Depress the tabs.
2 Separate the fitting.
Connect
µ 1. Align the tube to the fitting and push until you hear a click.
µ 2. Pull on the fitting to make sure it is fully engaged.
Fittings — R-Clip
Disconnect
WARNING:
WARNING:
CAUTION:
Do not use any tools. The use of tools may cause a deformity in the clip components which may cause fuel leaks.
µ 2. Remove the shipping tab by bending downward.
µ 3. Spread the R-clip legs and push the clip into the fitting.
µ 4. Separate the fitting from the tube.
Connect
1. Inspect the fitting and the tube for damage. Remove any dirt or obstructions.
µ 2. Insert the R-clip into the fitting.
µ 3. Align the tube and the fitting.
µ 4. Insert the tube in the fitting and push together until a click is heard.
µ 5. Pull on the connection to make sure it is fully engaged.
Matt Cherry
Feb 10, 2025 04:53 PM
airborne0130
Feb 25, 2015 04:53 PM
sslinn
Sep 29, 2014 10:11 PM
sowaxeman
Jul 30, 2014 06:01 PM
lm1d
1997 - 2003 F150
Dec 1, 2004 12:01 PM
