help, no KOEO, no spark, no fuel. checked the batt, +/- seems to be ok. ecm was tested, ok. i work on turbocharged buick regals, but the ford has me whipped! tia. pat myers chas,wv
[updated:LAST EDITED ON 06-Sep-02 AT 02:25 PM (EST)]I have the Ford EVTM and wiring diagrams from my 1989 Ranger. Send me an email and I'll scan what you need, please remind me what you want. On the 89 the relays were under the power distribution box, the thing under the hood with the high amp fuses.
>high amp fuses.
sir, if you have a copy of the e.c.m. wiring, i could use it! chilton book we have is worthless! color codes do not match. pat
I might need to scan it but it should be in your mail by tommorow evening.
On my 1989 there were three ground wires at the battery, the starter lead and two small black ones. One of the small ones had a fuse type holder you may check to see if this is connected and in good condition.
