Sponsored by: Real Truck
dang brake noises
Old Oct 29, 2004 | 07:12 PM
dieselstroke's Avatar
dieselstroke
Question dang brake noises
hi all, i have a 99 4x4 250, went you go to brake normal right before you stop
or slow down enough to turn the front brakes make a single pop noise and
then you don't hear it again, or at least until you go to stop again.The reason
i say when you go to stop normal is b/c i did have bad rotors and i would have to decelerate using engine compression quite a ways before i would use
the brakes so that i wouldnt warp them any more than they already were. But
i have new rotors and pads now.
Old Oct 29, 2004 | 08:09 PM
99f350sd's Avatar
99f350sd
Sounds like you have to pull the wheels and have a look wouldn't be the first time a pad STB...Make sure all bolts are tight..
Old Oct 29, 2004 | 08:13 PM
dieselstroke
wouldn't be the first time a pad STB? which bolts are ya referring to?
Old Oct 29, 2004 | 08:16 PM
99f350sd's Avatar
99f350sd
sht The Bed. All the caliper and frame bolts. sometimes a pad will come apart....The caliper frame or bracket.
Dick
Old Oct 29, 2004 | 08:22 PM
dieselstroke
oh, yeah their all tight. I really can't think of anything that can cause the noise
since the bolts are tight?
Old Oct 29, 2004 | 08:24 PM
99f350sd's Avatar
99f350sd
Like I said sometimes the bond between the pad and the metal comes loose...
Old Oct 29, 2004 | 08:28 PM
dieselstroke
the metal as in the backing plate? I can't see that happening.
Old Oct 29, 2004 | 08:36 PM
99f350sd's Avatar
99f350sd
The friction material comes off the metal...I have seen it.
