84 questions
Old Oct 29, 2004 | 04:13 PM
winchester54947's Avatar
winchester54947
84 questions
Hi All
Just Joined and I thought I would get all my questions in.
I think I have a 1984? w/5 lug wheels, 2 tanks, 351/460 engine (1978?) Automatic trans.
I'm wondering:
1. grvw listed as 6000 on door pillar. Is this f100, 150, ?; 1/2 or 3/4 T. has 'helper springs' on rear axle that contact brackets mounted on side of frame. Is this stock? I would like to put an 8' slide in camper on this truck. I just got 31x10.5 load C tires.
2. Just replaced front disk pads and I cannot find a zerk on the upper steering knuckle joint? Lower is in plane sight directly on top of joint. What am I missing.
3. No Backup lights in tail light assembly. Where would I look for a switch, on the trans, or the linkage or? I would like to add some.
4. I am starting to look for the rear cable and ? to repair the hand parking brake. Is this specific to certain model years?
thanks in advance
Old Oct 30, 2004 | 08:55 AM
ScottInTexas's Avatar
ScottInTexas
Give me coffee - Or beer!
Run your VIN code through a decoder. There are several on the internet but you'll have to find one that goes back to the year you suspect. I think the tenth character is the year code, but when I just looked I couldn't find one that decoded past 1980.
The rest of the vin will tell you body style, engine model and all other info. The gear code is on a tag bolted to the rear end. Can't tell you anything more than that, but I recall a couple of threads in this forum about rear end decoding. You may be able to find that info as well.
Sorry I couldn't help more.
Old Oct 30, 2004 | 07:45 PM
winchester54947
1fte15h8epb24282
looks like an f150
maybe an 82? I cannot find a vin decoder
any help would be appreciated...
I got to looking at the trans, has 4 wires from switch into connector. Problem I came across is that the only 'make' is for neutral.. bad switch? Seems like a schematic with wire colors would be the ticket.
