Sponsored by: Innova
XM Antenna Mount Options??
Old Nov 24, 2004 | 10:18 AM
Waldonian's Avatar
Waldonian
Under the cowl - is the reception okay? Does the antenna need to be unobstructed? Do the holes/slots in the cowl interfere?
Does anyone make a replacement third-brake light that incorporates a XM antenna? Would seem like a great idea.
Old Nov 24, 2004 | 01:49 PM
jinjimbob's Avatar
jinjimbob
I put my antenna wire out through the third brake light, really quite easy to do.
Old Nov 24, 2004 | 02:03 PM
2000silverbullet's Avatar
2000silverbullet
I did the same thing with my xm and nav antenna's. Just throw a tiny bit of silicone around it and it's as good as sealed.
I do like the idea of a replacement 3rd brake light with the xm antenna, Waldonian you might be onto something there. Run with it!
Old Nov 24, 2004 | 03:35 PM
tsc's Avatar
tsc
http://www.f150online.com/forums/sho...hreadid=121890
See the post by B-man (4-5 down). I used his Idea and have placed my anntenna in the same place, no problems yet.
***edit*** I ran the wire (covered in cable loom) across the front of the firewall with the other cables and went through the firewall on the driver's side by the steering shaft (there's a rubber grommet).
Old Nov 26, 2004 | 06:40 PM
hairboy's Avatar
hairboy
Waldonian, under the cowl is working good for me.
Mine is on the drivers side, so you can actually see it thru the slots.
Reception is just fine and you wouldn't know I had an XM antenna if you didn't know where to look.
Brian
Old Jun 16, 2005 | 04:12 PM
vrsc's Avatar
vrsc
Mine works good for me mounted under the cowl. This is a great stealth mod
Old Aug 2, 2005 | 08:50 AM
brettds's Avatar
brettds
Smile
I now have XM. I put the antenna under the cowl on the driver's side and ran the wire through the grommet right by the steering column. Turned out great! Thanks for all of the responses.
Old Aug 4, 2005 | 07:41 AM
shane77624's Avatar
shane77624
I prefer the dash mounting option....I kinda like the look of the little black puck.
