explorer front differential seal
Old Oct 28, 2004 | 07:27 PM
brucememp's Avatar
brucememp
I recently changed the hub on the right side 4x4.While doing so I pulled the axle out a little more than I should have.I now have gear oil leaking from around the axle.I'm guessing there is a seal in there that I messed up.Has anyone changed one?Also the gear oil level is low.Is this something I can change?Any help would be appreciated.
Old Nov 2, 2004 | 08:13 PM
brucememp's Avatar
brucememp
help
Anybody please!!!
Old Nov 2, 2004 | 10:14 PM
mrshorty's Avatar
mrshorty
What year Explorer? There's a significant difference in design between '94 and older and '95 and newer.
Old Nov 3, 2004 | 10:03 AM
brucememp's Avatar
brucememp
97 4 wheel drive.
Old Nov 3, 2004 | 11:16 AM
daerhldgs2's Avatar
daerhldgs2
yes there is a seal in the outboard extension from the diff and a bearing. Probably have to take the cover off or loosen it to drain the oil and refill to the plug level.
Old Nov 3, 2004 | 03:32 PM
brucememp's Avatar
brucememp
How hard is it to get to and change the seal?
Old Nov 3, 2004 | 06:04 PM
derek_seli's Avatar
derek_seli
Is the 95 and up fully independant? Or is it still the monsterous double swing arm like my 91?
Old Nov 3, 2004 | 07:45 PM
brucememp's Avatar
brucememp
I'm not sure what you mean about that.Maybe someone else can answer it for us.
Old Nov 3, 2004 | 10:37 PM
mrshorty's Avatar
mrshorty
The "monsterous double swing arm like my 91" is referred to as a Twin Traction Beam (TTB) suspension, and was used on Explorers from '91 to '94. '95 and up use a more traditional (if there is such a thing) IFS setup using A-arms and torsion bars.
Old Nov 4, 2004 | 08:14 AM
brucememp's Avatar
brucememp
Can anyone tell me where the seal is located?When I took the hub apart it didn't pull out from inside the differential,it was about halfway to it.
Old Nov 4, 2004 | 11:31 PM
daerhldgs2's Avatar
daerhldgs2
you have to pull the axle right out and the seal is the first thing you will see, then the bearing.
Old Nov 5, 2004 | 10:04 AM
brucememp's Avatar
brucememp
Your not talking on the end with the hub are you?It's leaking on the other end.Is it hard to pull the axle out?
Gembone
Aug 23, 2015 01:56 PM
joegeds
Oct 9, 2014 11:25 AM
DSMMH
Jun 19, 2014 12:36 PM
351Cleveland C4
Mar 15, 2014 09:36 AM
surveyguy
Apr 18, 2009 10:26 PM
