Turbo removal?
Old Nov 5, 2004 | 05:43 PM
RawPower's Avatar
RawPower
I cant wiggle either the snail (took its single bolt out) or the turbo. I can tell the turbo is getting looser, though. The turbo downpipe is disconnected from the exhaust but still to the y pipe, glanced at that one and didnt get it either. Im assuming its a clamp too, but I didnt see one. If it is a clamp, is it under the heat shield?
Are the 3 bolts holding the turbo on all facing the exact same direction? Are they all the same length? I know the two easy ones are... If not, there was one other bolt that only had about 1/2" of thread on it, under the turbo, and it was rusted. But it didnt look like part of the mount, so...
I dont want to go about cutting parts until I have replacements... just another excuse to get new stuff
Old Nov 6, 2004 | 12:35 PM
RawPower's Avatar
RawPower
Is there a clamp that holds the "inlet" exhaust's heat shiles to it? I have "fire-hardened" mud all around it so I can tell...
Also, I can move the snail in rotational directions, but not up or down. It takes some "gentle loving" from a hammer though... Turbos still toight loike a toiger.
Old Nov 6, 2004 | 09:51 PM
nogo73's Avatar
nogo73
send truck to me I need a turbo.
No the water pump isn't that bad heck lot better than those v6 SHO's.
Old Nov 8, 2004 | 01:11 PM
Ironpants's Avatar
Ironpants
I didn't get a chance to take any pictures this weekend.
It just occured to me that I have a 7.3 IDI that is on an engine stand in my garage.... - sheesh
I'll drag that out and take a picture of the back (it has no turbo on it, but the bolt holes should be easily seen).
I'll post the pics when I get them.
Old Nov 11, 2004 | 08:10 PM
RawPower's Avatar
RawPower
Thank you. I am still stuck.
v8steel
May 26, 2014 12:26 PM
rolape2
Apr 2, 2011 11:41 PM
lyonstail
Oct 13, 2008 03:43 PM
TexsDixieDiesel
Mar 7, 2005 09:34 PM
hotrodford_88
May 7, 2001 03:45 PM
