Starter Solenoid Clicks, Engine won't Start
Old Oct 28, 2004 | 04:59 PM
thedettras's Avatar
thedettras
I have an '83 F-100 3.8L V-6. When I try to start it, the started solenoid clicks, but it won't start. Trying to jump start it doesn't help, same clicking sound, but won't start. Any suggestions?
Old Oct 28, 2004 | 05:29 PM
NeoCowboy's Avatar
NeoCowboy
Well, if you want to do it the fun, yet dangerous way, you can cross the power posts on the solenoid with the key in run. This will get it started. If you want to be safe and have better luck starting it each time you might want to just replace the solenoid since its bad.
Old Oct 28, 2004 | 05:43 PM
thedettras's Avatar
thedettras
Forgot to mention that I alrady replaced the solenoid, and it still does the same thing.
Old Oct 28, 2004 | 10:35 PM
Franklin2's Avatar
Franklin2
Turn the headlights on. Then try to start the truck.
If the headlights go completely out, then your battery is bad, or you have a problem at connection # 1, or #2, or #3, or #4 in the diagram below.
If the headlights stay bright, then you have a problem at #6, or #7, or the starter is bad.
Old Oct 31, 2004 | 07:54 PM
thelonerangerxlt's Avatar
thelonerangerxlt
Thedettras, I see you have a 3.8L. If I'm not mistaken, the battery ground cable attaches to the starter housing on this engine. If this is true, remove the ground cable from the starter, clean the contact area, and re-attach.
