44hd in highboy
Old Oct 27, 2004 | 09:13 PM
mo_fordman's Avatar
mo_fordman
44hd in highboy
has anyone put disc brakes on a closed knuckle front end if so what does it consist of???THANKS
Old Oct 27, 2004 | 09:45 PM
rakent's Avatar
rakent
Do a little poking around in this forum and you'll find a bunch of threads on this topic. In general, the concensus is that you will need to swap axles to get disc brakes. The easiest is a D44 out of a '76 or early '77 F-250 4wd, as the spring perches and steering setup will be the same. These can be hard to find, however.
Good luck.
Old Oct 28, 2004 | 12:15 AM
highboy1975's Avatar
highboy1975
yea, just swap the whole axle, probably less work and money depending on the axle. i went with a d60 in my swap instead of the 44. figured i already had it out, why not?
Old Nov 14, 2004 | 11:06 PM
1973F250CREW's Avatar
1973F250CREW
I have closed knuckle disk on my '73.
Old Nov 15, 2004 | 08:19 AM
rakent's Avatar
rakent
How did you go about the swap?
Old Nov 15, 2004 | 12:05 PM
1973F250CREW
44hd in highboy
It already had disk brakes and closed knuckle when I bought it a couple of months ago. I have never done a swap, so I don't know the details. I should have my gallery going in a few days so I can show pics of it.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
