61-66 F100 Registry
#391
Transmission advice
I recently bought a 1962 F100 unibody and I'm the process of restoring it to working condition. The previous owner had put in a Pontiac engine (which no longer runs) and, I'm guessing, a GM automatic transmission. I found a 292 Y-block for it, but haven't decided on a transmission. I was leaning toward a 4-speed toploader, you can get adaptive bell housings to make it work, but would also consider an automatic. Anyone care to give an opinion?
#392
Engine and transmission .
#393
Well truthfully , it all depends on what you want it’s your truck ,I know that 3 speeds on the column was the real deal for these trucks . But if your using it as a everyday driver a ; speed is the way to go. Personally I have a 3 on the tree 292 in mine and I rebuilt the column and it works perfectly. I really didn’t want to loose the originality of the truck . Most people love it the way it is due to most people change it to the floor. Again it’s all about preference , but I always say it’s only original once and if it works and you can live with it . Leave it alone .
BTW, I see you're from Fairless Hills, I grew up in Bristol, PA
#394
Actually, I find Quite a few trucks in Virginia. on face book Market Place . I drove down to Virginia to pick up a parts truck for less than a grand I got a complete power train 292 v8 with a 3 speed and all the original trim I needed for my truck. In my original truck I had a 232 straight 6 with a 3 speed and it ran well . but I wanted a V8 . Now I got it !
#395
1963 F100
1963 F100 Styleside
Long bed, regular cab
Vin: F10JR440***
223 I6
T18 4 speed (reverse upper right, non-synchro granny first)
Triple carb Offenhauser intake
Sidepipes
White top, lower silver
White interior, red piping
Front end disc brakes
Located in Atlanta area
Currently with Cragars - original wheels and hub caps being restored
Soundproofing and installing AC next
Vin: F10JR440***
223 I6
Sidepipes
#396
Daily driver
65 F100 longbed styleside custom cab
Original 352 .030 lumpy cam, Mallory, edelbrock, Holly 4bbl rusty headers and flowmaster true dual
original light duty 3 on the tree, original 3.5 rear
Caribbean turquoise and white plastidip by PO
Riding on 31's on 80's alloys
F10DR68XXXX
Project;
63 F100 LWB Unibody
OE 223, 3 Tree 3.89-1 Raven black
Planned; Foxbody mustang front K member with coilovers ps, pb disc rack and pinion,
HIPO 5.0 T5 And the original nine inch
Currently is toxic chromic yellow with enough patina for three trucks
F10JR33XXX
Both are California trucks from the San Jose plant
#397
#399
Stewart_H
52
04-23-2024 07:31 AM
ptgolfer7
New Member Introductions
09-25-2017 05:12 PM
