Starting problems
Old Oct 27, 2004 | 12:18 PM
Old Paint's Avatar
Old Paint
Starting problems
Hey Y'all
Here lately my 93 F150 takes 2 to 3 grinds on the starter to get it to fire.
Replaced pickup coil in distributor, ignition module, checked fuel pressure, checked fuel pumps, cleaned plenum, replaced fast idle motor, and checked for codes (none). Plugs, wires, cap and rotor good. Truck has 204 k miles on it.
Attn: Broken wire, I've read your threads and you sound like a technician. If you or any one else has any suggestions I would appreciate it. Oh yea, engine
is a 5.0.
Thanks
Old Paint
Old Oct 27, 2004 | 12:37 PM
68torino's Avatar
68torino
How is the timing? Might want to do a compression check if it has alot of miles. May be getting tired.
Old Oct 27, 2004 | 09:04 PM
Old Paint's Avatar
Old Paint
Will give it a try.
Thanks Duane, even though I've changed the oil faithfully every 3k I will do a
compression check. I thought it improbable at first but now that you mention it stranger things have happened with the best maintained machinery.
Old Oct 28, 2004 | 09:13 AM
Old Paint's Avatar
Old Paint
Distributor
Could it be the distributor? should there be any play in the distributor shaft?
