Momentary Hesitation
Old Sep 21, 2002 | 08:15 PM
rebocardo's Avatar
rebocardo
Old Sep 26, 2002 | 11:52 AM
1998XLT's Avatar
1998XLT
Twice in the past week this has happened. Its like a moment of power loss or "limbo", when I gas it, it goes away. The first time I had slowed sharply then went around a curve and with the truck at about 10-15 mph the momentary hesitation happened. The second time I went down a sharp hill and turned to the right again and felt the same thing. I have almost 59,000 miles, just changed fuel filter at 55,000. Wonder could it be the fuel pump going? Also my mechanic says that engine needs the timing belt changed at 60,000,,,,,could it be the belt jumping time???
Thanks.
Old Sep 26, 2002 | 10:30 PM
bubbernator's Avatar
bubbernator
Doubt it. When a timing belt skips a tooth the motor gets ugly and stays that way until it's fixed. You didn't mention engine or trans.
I've had a couple hesitation blips on my 2.5l. Hit the gas and no power, almost like the computer has a brain fart. Clutch it, rev it once and away I go. No error codes on the dash, either. Haven't figured it out yet, but I've seen several posts from people with the same problem.
CB
Old Sep 27, 2002 | 07:39 AM
1998XLT's Avatar
1998XLT
Automatic Overdrive, yeh, it could be an overdrive thing...I guess I better start asking for replaced parts back,,,how do I know my mechanic REALLY did change the fuel filter.....
ALSO, have you heard what he told me about that engine needs timing belt changed at 60,000...I am only about a thousand from that.
Thanks.
Old Sep 27, 2002 | 08:18 AM
Ken00's Avatar
Ken00
60k is normal for a belt.
Old Sep 27, 2002 | 01:40 PM
1998XLT's Avatar
1998XLT
About timing belt, I have heard different stories about when it goes, years ago, your vehicle just stopped running until you got i fixed, I think, now people are saying your engine will get screwed up if it breaks while driving......???
Thanks
Old Sep 27, 2002 | 02:16 PM
greenpus's Avatar
greenpus
I have about 48,000 on my 2000 2.5 and I had that happen a total of 3-4 times. Push on the gas and no go, it just boggs down and runs rough.
I just put up with it.
>CB
Old Sep 27, 2002 | 03:47 PM
Ken00's Avatar
Ken00
>Thanks
I can't recall the term that is used right now but I believe most new engines with belts will not be damaged if the belt breaks. What happened in the past was the pistons hit the valves.
Old Sep 27, 2002 | 03:59 PM
Rand's Avatar
Rand
[updated:LAST EDITED ON 27-Sep-02 AT 05:00 PM (EST)]I think its called Interference and non-interference engines?
or am I thinking of something else Ken?
Rand
I think someone else referred to this as a freewheeling?!?engine before?
Old Sep 27, 2002 | 07:47 PM
Ken00's Avatar
Ken00
>engines?
>Rand
You hit the nail right on the head Rand, thanks, see what happens when you work to much and don't visit the Ranger boards.
Old Sep 27, 2002 | 08:04 PM
bubbernator
Check my post from a week or so back titled "Timing Belts". Just click on the hyperlink, you don't have to cut and paste.
It links to the Gates Rubber Co. catalog.The "interference engines" are marked by asterisk. That means that if the belt breaks while the motor is running the pistons slap the hell out of the valves.
I'd been told by an AutoZone employee that I had one, and sure enuf his computer listed it that way. Gates does not and Ford does not.
Also, the replacement interval changed on the '98 and '99 2.5's. Gates reccomends inspecting at 120,000 and replacing if needed for the '98 and replacing at 120,000 for the '99.
Remember that this is information from the belt manufacturer and it's in their interest to sell more belts.
CB
Old Sep 30, 2002 | 12:24 PM
1998XLT's Avatar
1998XLT
Wonder why in the Gates catalog listings, all up to 1997 say replace timing belt at 60k, but 1998 on say at 120k ???
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
