Can I Tow 6000#
Old Oct 26, 2004 | 01:48 PM
keithmartin's Avatar
keithmartin
Question Can I Tow 6000#
I have a 2000 Explorer XLT with V8 and towing package. I am considering purchasing a 4500# travel trailer with a 6000# max GVW. With an equalizer hitch, can I tow this up/down hills at freeway speeds? Any Explorer owners out there with experience?
Old Oct 26, 2004 | 04:13 PM
Steina's Avatar
Steina
CO River Rat
With just the loaded trailer, you're gonna be real close to the max towing limit. If you have 4 people and gear in the Explorer, you're gonna be over the limit. Deadweight on the hitch could be as high as 900#, so an equalizer hitch is a must.
I tow a 2980# boat/trailer rig with my '04 Explorer (V8 with tow package), plus 4 people and gear. It does pretty well on hills, but I wouldn't want to add another ton-and-a-half to her tail. Plus, a TT has a lot more frontal area than a boat.
Steve
Old Oct 27, 2004 | 05:55 AM
JerNla's Avatar
JerNla
Well the maximum towing capacity is 6820# so is pretty close. Just pack lightly and go on a diet and it might be fine.
Old Oct 27, 2004 | 09:03 AM
CobraXP's Avatar
CobraXP
It will do it, but you will put a pretty good strain on the drivetrain. Loaded out with the trailer and people, you will right at the limit. Two things besides the equalizer hitch - get trailer brakes and get some type of adjustable shocks or airbags for the rear. Those two things are pretty much a must. You might be able to pull it, but without trailer brakes, you won't stop it. I would suggest getting something like the Gabriel adjustable air shocks for the rear. It will help the IRS even more by helping againt the rear sag.
Old Oct 27, 2004 | 09:26 AM
Steina's Avatar
Steina
CO River Rat
CobraXP -
Keith has a 2000 Explorer - IRS wasn't added until the 2002 model year.
Steve
Old Oct 27, 2004 | 10:28 AM
CobraXP's Avatar
CobraXP
Originally Posted by Steina
CobraXP -
Steve
Don't know why I thought he had the 2002+.... I need to wake up and start reading before typing....
Old Oct 27, 2004 | 04:35 PM
Steina's Avatar
Steina
CO River Rat
CobraXP -
Thought I was the only one who did that!!!
Steve
Old Oct 27, 2004 | 05:20 PM
CobraXP's Avatar
CobraXP
I usually check the boards right when I get to work. Sometimes I read what I want instead of reading what was actually posted...
I gotta stop doing that...
Old Oct 27, 2004 | 08:37 PM
performancenut's Avatar
performancenut
Suggest a transmission cooler, weight distributuin hitch with some after-market reinforcement bars from a hitch shop, and a mechanism to lift the rear (air shocks and air bags) as the weight will likely lower the back quite far. Even a heavy-duty transmission shift kit would help your transmission and drive train. Have you considered safety issues with the family in the vehicle also?
