Hey, What's This Thing
Old Oct 26, 2004 | 08:50 AM
gpeade's Avatar
gpeade
Hey Folks, Dumb Question.
What Is This Contraption Under The Truck On The Rear Most Crossmember? It Appears To Have Fuel Lines And Wires Running To It. Am I Right? Is The The Fuel Pump?
Old Oct 26, 2004 | 08:53 AM
chrono4's Avatar
chrono4
if i am thinking right and you have the duel tanks then it would be the fuel selector vavle.
Old Oct 26, 2004 | 03:55 PM
Harrski's Avatar
Harrski
I was wondering the same thing. I first saw it in the brochure and then when I got mine saw it, but never quit figured it out. It's definately not a fuel selector valve because none of the 04F150s have dual tanks
Old Oct 26, 2004 | 04:12 PM
gpeade's Avatar
gpeade
I Also First Noticed It In The Brochure But Figured I Find Out Once I Got It Home. Haven't Done Any Research Just This Post. Someone Knows What This Is.
Old Oct 26, 2004 | 04:20 PM
super440's Avatar
super440
I'm not sure, havent looked myself, but I suspect it has to do with fuel vapour management.
Old Oct 26, 2004 | 05:17 PM
Harrski's Avatar
Harrski
I had a 2001 F150 SCREW before the 2004. I installed a tailgate lock actuator that ran off the drivers door lock switch and the key fob. Also I bought bigger tires on new rims and bought a 5th one for a spare and when I realized the new tire, because of the wide width was hanging down too low and rubbing on the ground when going off road I put it in the bed and removed the spare tire winch under the bed and both times never noticed anyting remotely similar to this thing on the new trucks. If I remember I will climb under on the weekend and see where those lines go. Wish me luck
Old Oct 26, 2004 | 06:57 PM
SHANE_2's Avatar
SHANE_2
You guys are most likely referring to the Vapor Canister. It is right above the spare tire on most.
Shane
Old Oct 26, 2004 | 08:53 PM
chrono4's Avatar
chrono4
oh sorry about that i was in the 87 to 96 and on the home page at the same time and i saw that on the home page as a recently viewed thread and when i opened it i automaticaly assumed it was in the 87 forums. sorry bout that. thats the only reason i asumed it was a fuel selector valve.
chrono
Linda Ann
6.7L Power Stroke Diesel
316
Oct 5, 2016 06:50 PM
deano-was-his-name-o
17
Mar 26, 2009 12:58 PM
frdtrkgrl
Jan 21, 2006 08:21 AM
dougandrochelle
Modular V10 (6.8l)
Dec 28, 2004 07:31 AM
muddawg
Jan 29, 2002 11:42 AM
