Power window sluggish!
Old Oct 26, 2004 | 12:10 AM
PWRSTK2K's Avatar
PWRSTK2K
Since the weather has cooled down lately - low 40s at night, my driver side power window has slowed down to a crawl. Barely goes up and down - sometimes stops. Anybody else had this problem? Its a 2000 and the pass side works great.
Old Oct 26, 2004 | 12:15 AM
psdpower's Avatar
psdpower
Had the problem with the pass. side on my 99. I sprayed some silicone tire dressing on the window tracks thinking it would help a little until I got around to properly fixing it, well a year and a half later and the window still works great so I haven't actually tried to fix it properly. The silicone tire dressing pretty much solved it for me and if it doesn't work your out like $4.00 for the tire dressing.
Old Oct 26, 2004 | 12:19 AM
PWRSTK2K's Avatar
PWRSTK2K
Thank you very much - will try that tomorrow.
Old Oct 26, 2004 | 05:26 AM
Jerrybo66's Avatar
Jerrybo66
I don't know about tire dressing but I've used the standard silicone lubricant and it works. I saturate the fabric guides well and let it dry. I apply it about once a year.
Old Oct 26, 2004 | 11:28 PM
PWRSTK2K's Avatar
PWRSTK2K
Thanks to you Jerrybo66 - as i didn't get around to the store today I'll buy the silicone lube instead.
Old Oct 28, 2004 | 10:12 PM
PWRSTK2K's Avatar
PWRSTK2K
Jerrybo66 - I didn't think to ask you if you remove door panel to do this or just slather it on in the exposed areas. I put some on in the exposed areas and right away saw some improvement but will pull door panel if needed - thanks for all you help.
Old Oct 28, 2004 | 10:23 PM
WA.Ranger's Avatar
WA.Ranger
PWRSTK2K- I also had the problem and used the silicone spray. I put it just in the exposed felt. Worked like a charm. My Pop's D$$$$e also was getting sluggish, we did his and it cured it.
Old Oct 28, 2004 | 11:19 PM
Jerrybo66's Avatar
Jerrybo66
I do just as the Ranger said. I think in time the window drags some of the silicone down the track. Taking off door panels isn't my idea of fun..
. I also use it on the rear window slider, the windows in the cap and the windows in the house. It's pretty good stuff when you need a lubricant and don't want a greasy mess. The stuff I have is made by Prestone. I'm sure you will be pleased with the results.
PWRSTK2K's Avatar
PWRSTK2K
Thanks Ranger!
Old Oct 28, 2004 | 11:21 PM
PWRSTK2K's Avatar
PWRSTK2K
Thanks to Jerry too!
