1978 - 1996 Big Bronco
92 Idle problem
Old Nov 2, 2004 | 07:28 AM
Peanut_THumper's Avatar
Peanut_THumper
well the problem I see there, is if you spray to much - inside anyways - is damaging the tps. on the outside -spring coils - I would use wd-40 .
I picked up the new tb and guess what...it comes with a new TPS and IAC.. and I now know that I got taken by that mechanic....
Old Nov 2, 2004 | 01:56 PM
Peanut_THumper
Well I replaced the throttle body and all is GREAT !!! so any of you who have replaced EVERYTHING- you might want to check out that throttle body...
Good Luck to all of you and thanks for the input!
Old Nov 2, 2004 | 01:57 PM
Peanut_THumper
Hi Rudder.. my throttle body was the key so you might wnat to take a closer look at yours...Good Luck..
Old Nov 2, 2004 | 04:54 PM
broncobillybob's Avatar
broncobillybob
Hmmm...I was thinking about getting a 56mm TB maybe now I can justify it alittle more.... I guess it was just a simple bolt on and nothing superhard. -Bill
Old Nov 2, 2004 | 05:06 PM
Peanut_THumper
no it was 4 bolts and real easy.. you will have to pull off the small hoses and the power cords to IAC an TPS, you'll loose a little anti freeze .. but thats it ...simple
the guy at ford told me to leave the battery off for atleast 30 min, and the computer will reset every thing and off I went...
btw- the stock tb comes with a new tps an iac...
Old Nov 2, 2004 | 05:17 PM
broncobillybob
How much did it run you and where did you buy it from? Did you need a replacement gasket?
