Y-Block Heads
Old Oct 24, 2004 | 09:06 PM
DGMFORD's Avatar
DGMFORD
Y-Block Heads
Are the Y-Block heads (Truck) all the same, say from 1955 to 59? I have a 292 and one of the heads I noticed today has a crack in it. I have 2 more sets but they are 272 and are from a 1955 model. Will these heads interchange?
Thanks
Old Oct 25, 2004 | 09:46 AM
312's Avatar
312
all y heads from 55 up will change.you have different size valves and different comp,ratios over the years.
Old Oct 25, 2004 | 06:07 PM
286merc's Avatar
286merc
You should use the same casting ID in order to have equal compression between sides.
That being said Ive seen a perfectly running 292 with G heads on one side and C on the other! But that was in a F600 that didnt ever see much over 30 mph.
Old Oct 25, 2004 | 10:11 PM
DGMFORD's Avatar
DGMFORD
ok, I will check the casting numbers on the ones I have and try to find a match. Does anyone know who may have a 292 head for sale? thanks for the help.
My casting number is COTE which Is a 1960 model head.
Old Oct 26, 2004 | 08:55 AM
286merc's Avatar
286merc
C0TE is a peanut valve head, not good for much of anything except low end in a slow moving big truck.
ECZ-A and -C are fairly common out here wheras everyone thinks the large valve heads are their 401K
Old Oct 27, 2004 | 09:43 PM
DGMFORD's Avatar
DGMFORD
Thanks everyone, I have a set of ECZ-C heads off my 56 272, will those heads fit the 59 292?
Old Oct 28, 2004 | 09:16 AM
286merc's Avatar
286merc
Absolutely. You might want to have them surfaced.
Old Nov 13, 2004 | 11:15 PM
Rocklock's Avatar
Rocklock
COAE heaqds for Y Block
I just completed new engine using G heads. Have a set of COAEs. Good used condition. Car ran fine just toomany leaks when I rebuilt.
$100 + frt for the pair. Ship from 75601.
Rocklock
Old Dec 20, 2004 | 11:22 PM
hudsonmand
Guest
Posts: n/a
i have a set of COTE6090A heads if still needed email at hudsonmand@yahoo.com
Old Dec 21, 2004 | 06:42 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
WELCOME to the site, please read the Guidelines… Check out the list of forums and make sure you read the headings and Read First: notices in each forum.
You have email
fastphil
Jan 4, 2013 10:26 AM
abe
Apr 15, 2009 02:53 PM
bolivious
Nov 10, 2006 06:12 PM
NJ239Y
Jun 9, 2004 08:13 AM
