Dies, hard start, pinging
Old Oct 28, 2004 | 09:36 PM
pfogle's Avatar
pfogle
Okay, then the PIP in the distributor is probably bad. It's sending odd signals to the computer. What did the codes indicate? 31 is EGR I believe, 11 is all clear... I'm not sure what the 10 code is.
Old Oct 28, 2004 | 10:10 PM
papadace's Avatar
papadace
Code 31 is the EGR, possibly hanging open and killing engine? Could cause pinging too if it isn't opening right.
Old Oct 28, 2004 | 10:49 PM
ACESN8S's Avatar
ACESN8S
I picked up a digital readout scanner. 10 is a "separation code", it separates the key off engine off codes, from the continuous memory codes.
Before I changed the ICM, I got 21, 31, 77, 25 while it was running.
After I changed the ICM, I got 12, 16, 13, 77, 25 while running.
I've even tried running it with the SPOUT unplugged.
Patrick
Old Oct 29, 2004 | 01:57 PM
ACESN8S's Avatar
ACESN8S
I took the distributor out this morning, has quite a bit of slop at the base by the gear.
So I'm just going to replace the whole thing.
I see that these came with cast or steel gears, how do I tell? Besides a magnet, because the gear is still on the shaft and the magnet just sticks.
edit:
Nevermind, I was able to have the number ran, it's cast.
Patrick
Old Oct 29, 2004 | 09:05 PM
pfogle's Avatar
pfogle
Yeahm replacing the whole unit was the way to go. There should not be any movement in the shaft at all side to side.
Old Oct 30, 2004 | 02:13 PM
ACESN8S's Avatar
ACESN8S
I replaced the distributor this morning....same thing
Runs for a few then dies.
Patrick
Old Oct 30, 2004 | 04:16 PM
ACESN8S's Avatar
ACESN8S
OK here we go.
I replaced the EGR sensor.
With the key on engine off, code is 11.
While it's running, All I can get is: 8 (for cylinders), then 34 and 13. Then it dies.
Old Oct 30, 2004 | 04:33 PM
pfogle's Avatar
pfogle
What does the book say about those codes... It should flash a 4 indicating 8 cylinders, then 5 to 15 seconds later and impulse flash, which at that time you need to turn the wheel, press the brake, and goose the throttle. Does it run with the scanner attached? Drive it with it hooked up and see what it does.
Old Oct 30, 2004 | 04:58 PM
ACESN8S's Avatar
ACESN8S
No it will not stay running, even with the scanner attached.
My scanner is a digital readout, so it gives me the code numbers.
I did what you said, turn wheel, step on brake and goose it.
I can only get a 34 and a 13 then it dies.
In my book it says code 34, test condition O,R,C (trucks only): is a EVAP control system fault, voltage higher than closed limit (V8 model only)
13 says RPM at idle out of range/low
Patrick
Old Oct 30, 2004 | 05:28 PM
pfogle's Avatar
pfogle
Ok, that sounds like a bad TPS.... Which could cause some of the symptoms..... It can be tested. There are three wires, red, green, and black. The red wire should have +5V with the key on, the black is a ground, and the green is the return to the computer. The green wire should be ~.9 volts at idle, and ~5v at WOT... It should change smoothly through the range. I'd start there now that it's setting other codes.
Old Oct 30, 2004 | 05:51 PM
ACESN8S's Avatar
ACESN8S
Mine only has two wires. Red and Green.
So fart I've only tested it NOT running. 0 volts on both while key is off.
Key ON, Engine OFF: Red has 12.47V and Green has .10V
I'm going to run back out in a second and check it while running.
Old Oct 30, 2004 | 06:04 PM
ACESN8S's Avatar
ACESN8S
Oops, checked the wrong thing.(Air idle conrol valve)
I checked the thing on the side of the throttle body.
But now it won't start at all.
Old Oct 30, 2004 | 06:21 PM
  #28
ACESN8S's Avatar
ACESN8S
OK right item now. It has 5.12v with the key on (red) and 1.2v for the green.
I can't get it to start.
I did notice that in the wiring harness for the Air idle control valve, that there are two wires the same color coming out of the harness and looping through a large gray item that says DIODE on it. The Red wire goes into one side and the Green wire goes into the other. Now the green wire is almost broken in half right at the edge of the diode.
It turns over, but that's it.
Old Oct 30, 2004 | 06:50 PM
  #29
Babin's Avatar
Babin
That's an interresting thing, but I'm missing one thing (french canadian): what does pining mean?
Thanks
Old Oct 31, 2004 | 06:31 AM
  #30
pfogle's Avatar
pfogle
Ping is spark knock. Ok, you need to fix the IAC harness... It's now probable throwing a code.... Unfortunately... The TPS voltage is a little high, I'd replace it.. When mine read that high it idled at 1500 rpm.... I think I'd also remove and clean the IAC while your at it, sounds like it's not working.
