I have a '91 F150 with rear anti-lock brakes. The problem is the rear brakes lock up with just a moderate amount of pressure on the pedal which makes it fun driving on wet streets. The ABS light stays off like it's operating normally and there are no trouble codes.
Check your rear brakes for a axle seal or wheel cylinder leak. I know this sounds funny since you would expect the oil on the brake shoes to cause them to slip not lock but trust me.
Every Ford truck I've ever owned with rear ABS has had the same problem - rear axle lock up. I've noticed with all my trucks it only happens after the truck has sat outside in rain or snow during a cold start situation. The rear axle will lock up the first time I apply the brakes when the vehicle is cold...then it acts normal. I've driven Ford trucks at work that did the same thing. I always figured it was a normal for this to happen.
My 1994 F150 Flareside did the same thing this morning at the end of the street, then all was normal...its just something I've learned to live with.
Glenn
1989 F150 2wheel drive
I have exactly the same problem as Flareside .. the very first time I apply the brakes after cold start they lock; afterwards all is normal.
Some past discussions mentioned that this is a common problem - replacing the wheel cylinders fixes the problem according to one of those threads (sorry I don't have a reference for you).
Seems to be an annoying but not critical situation.
I can verify that. My old POS would lock one up really bad after it sat in the damp weather. The one it wanted to lock up was the one were the axle seal was bleeding all over the brakes.
I think it has nothing to do with the ABS, in fact, if the ABS light is on the system is disabled anyway. The problem is that the brake shoe material absorb water and get really grabby. The worst is when they sit for a fairly long period of time in damp weather, but use the brakes lightly a couple of times so they dry off and they are fine until they sit again.
Had similar problem with chev astro. First couple of brakes and the fronts locked up nasty. So I learned to lightly ride the brakes for half a block to warm them up and burn off the moisture.
I wonder if there's any worth to considering the wheel cylinders - its somewhere in the past discussions where that fixed it for one of the FTE members.
Yes daajr, it always surprises me when I roll down the hill to the stopsign after backing out my driveway and skid to a stop. I may be doing 5 mph since its only about 10 yards.
Might try contacting those FTE members directly - various opinions on quality of brake shoes/lining affecting (Ford oem, NAPA , etc..). Since it seems to be so common a problem I just live with it, but when I need my next brake job I would like to know what I can do to eliminate it.
