Serious Problems Need Help ASAP!
*wires are located on bottem right side of the projectors on front side directly lined up with the wires are the 5 led lights. My guess is the wires light up the Rings around the High & Low beam aswell as light up the 5 led lights?
1)Back View Wire harness (Left Projector)
( white&red-----------------------red&black------------------------------red&white )
2)Back View (Left Projector)
---------------------------------------------------------------- ^ Wire Harness ^ ----------------------------------------------------
3)Front View (Left Projector Upside Down)
---------High Beam Socket Low Beam Socket Corner Socket-------
-----------------------------5 LED Lights-------------------------
you say you tried replacing the flasher relay? if you didnt already i'd suggest replacing it with a Variable Load (12v) electronic relay. are those LED turn signals? if so they may not be drawing enough power, you'll need to wire in some resistors
