'96 Explorer squealing noise
Old Oct 24, 2004 | 07:25 AM
Fulmerman's Avatar
Fulmerman
Started squealing first only when engine was cold, stopped after it warmed up. It did this for three or four days, now the squealing is louder and doesn't go away. It gets higher pitched as you accelerate. Any ideas?
Old Oct 24, 2004 | 08:57 AM
5.0EBExplorer96Snow's Avatar
5.0EBExplorer96Snow
Check your drivebelt pulleys. If you take it to a repair they will probably tell you its your water pump. Had a similar problem with my 5.0L AWD last year it took about 20 min to change. The parts (2 pulleys) cost $25.00. Pep boys quoted $202.00 to change the water pump or $508.00 if they borke a hard to remove bolt on the pump and replace the timing cover. So if I were you I would have the pulleys checked first. Beware of the water pump theory.
Old Oct 25, 2004 | 10:48 AM
pax's Avatar
pax
If you can't isolate the noise while the engine is running. I would take the belt off and spin all the pulleys, accessories by hand to find any loose bearing, binding, etc.
I had a squealing problem on mine too. It turned out to be the AC clutch was making the noise when it is free wheeling. It was a high-pitched scratching noise. It still spins ok, just making noise, I guess the bearing is going soon.
Old Nov 15, 2004 | 09:01 PM
DukeandKathy's Avatar
DukeandKathy
I have a 95 Explorer and I have the same squealing noise. I replaced just about everything the belt spins and the squealing continued. I took the belt off and ran the engine and the squealing still continued. It squeals at startup and then stops when it warms up. I have read about a couple of folks with the same problem, but I have not seen the reason or the solution yet. Is there anyone out there that has beat this problem. Thanks.
Duke
Old Nov 16, 2004 | 07:14 AM
mason's Avatar
mason
Cam position sensor is most likely the problem. Try searching this forum. Here is one discussion: https://www.ford-trucks.com/forums/s...sition+sensor+
Mason
Old Nov 16, 2004 | 11:18 AM
drcoffee's Avatar
drcoffee
for a quick check, one by one spray WD40 on each pulley shaft (with engine off for safety) until it stops squealing. then change out the part. Mine did exactly as yours is and my issue was the upper idler pulley.
Old Nov 25, 2004 | 06:09 PM
DukeandKathy
Squealing Noise Fixed!!!
Thanks Mason for the solution to my problem. It was the camshaft position sensor. I had it replaced. The shaft of the sensor was seizing up. I could barely turn it by hand when it was removed. The part was $434 and the labor was $243, a little costly but the car has never giving me any trouble in the 208,000 miles I have owned it.
Mason, thanks again for the help.
Duke
78_ford_F150
May 18, 2022 12:26 PM
fordboy97
1997 - 2003 F150
Feb 24, 2016 12:08 PM
Ron94150
Oct 5, 2015 11:28 AM
351Cleveland C4
Offroad & 4x4
Jun 13, 2014 07:00 PM
stangman516
Dec 13, 2007 07:33 PM
