Trash or treasure?
Old Nov 10, 2004 | 03:09 AM
RR4E's Avatar
RR4E
My 69 had drums all around, and PB on it. I converted it to front disk thanks to a donor 79 Bronco, along with many other parts I used off of it including the tilt steering column, the NP 435 trans, and 2 speed t-case, PS box and pump, intermittent wipers. I already had a 32 spline 9-inch with posi out of another truck, and was lucky enough to match the gear ratio's for the front end on the Bronco to make the swap super easy.
Old Nov 10, 2004 | 07:33 PM
marty0108's Avatar
marty0108
Man ..what An Adventure..only For A Truck Would A Man Go Throught All That. We Are Proud You Are A Ford Owner....kepp Truckin
