Aftermarket Products
Sponsored by: Worksport
Strobe Light Installation
Old Oct 23, 2004 | 07:03 PM
F-7's Avatar
F-7
Has anyone drilled into the head light assembly. Any info would be helpfull
Old Oct 23, 2004 | 07:07 PM
5_labsownus's Avatar
5_labsownus
We do this to vehicles at work all the time. But we are exempt from state regs. Check your state laws to see if it would be legal to install these lights.
Old Oct 23, 2004 | 07:46 PM
F-7's Avatar
F-7
The truck is a 2004 supercrew. I just want to be careful with the drilling part. Not worried about the laws Thanks for the reply.
Old Oct 26, 2004 | 02:20 AM
A_Fire_InsideR1's Avatar
A_Fire_InsideR1
im about to do the same thing once my clear corners come in i'd also be interested on anything ppl have to say about it.
i'd just try to use common sense and not crack anything...
Old Oct 26, 2004 | 03:58 PM
13MWZ's Avatar
13MWZ
I did it when we got a new f350 as a first responder truck. No problems in over 5 years. The strobes came with rubber gromets, but to be safe I ran a bead of clear RTV along it for extra sealant power!
I put a red in the drvs headlight, a blue in the pass headlight, a blue in the drvs corner, and a red in the pass corner, blue ones in both reverse lights and clear ones in both taillights. All that in addition to the strob bar up top, the strobes flush mounted in the tailgate, and strobes mounted on the grill guard.
Better wear some sunshades when you flip the master switch!!!
Old Oct 26, 2004 | 04:26 PM
A_Fire_InsideR1
haha awesome! i'm probably just gonna do white strobes. offroad/show use only ya know
Old Oct 26, 2004 | 04:32 PM
ArkansasFordMan's Avatar
ArkansasFordMan
Hey 13MWZ I have a question about the red strobes that you used in the headlights. I am a volunteer FF/EMT and have thought about using the red strobes, but I was warned that the red ones tend to look pink when they flash, is this true? Or do they look dark red like they should? I was afraid after hearing that so I just went with the clear ones in my headlights on my Mustang and use a plug in red dash light. Next question is did you get the red strobes from Galls? Thanks for the info.
Old Oct 26, 2004 | 07:24 PM
F-7's Avatar
F-7
Inside R1 Me too show only. I also go snowmobiling up North almost into Canada. Hit some bad storms going threw the mountains it snows so bad you can only see about fifty feet sometimes. I went with the amber. I will install one in each headlight and one in each reverse light section of the tail lights.
Old Oct 26, 2004 | 11:59 PM
13MWZ's Avatar
13MWZ
Guess it depends on the quality of the strobe. The ones we had (sorry, dont remember the brand) looked pretty good. They didnt look pink at all. What ever you do stay away from the ones that use the colored rubber boots. Those are the ones that look terrible. The stuff in galls.com is usualy good quality stuff.
Old Oct 27, 2004 | 12:34 PM
Cuda444's Avatar
Cuda444
In response to drilling into the actual headlight... be careful, as the reflecting portion of the housing is usually curved and then there is an outer housing of black plastic... making the appearance of a flat surface... an easy way to check is to take out the bulb and feel inside, if it's curved, I wouldn't try mounting it there... when I did mine, I drilled into the bottom of the turn signals, it's flat there, and... if you do screw up, a new directional on ebay is a lot cheaper than a new headlight Hope this helps
Old Oct 27, 2004 | 07:51 PM
F-7's Avatar
F-7
Thanks Cuda. Called a friend of mine that ownes a body shop he is going to install the strobes I can handle the rest. Does anyone have a 150 supercrew can I get power supply behind the back seat?
tjdad62
Aug 19, 2011 05:42 PM
big red ranger
1983 - 2012 Ranger & B-Series
15
Feb 20, 2011 06:29 AM
skip hatfield
2004 - 2008 F150
Mar 17, 2010 02:02 AM
mwh
2004 - 2008 F150
Sep 7, 2004 08:32 PM
redvet
May 28, 2002 09:40 PM
