rear antilock idiotlight
Old Oct 23, 2004 | 06:49 PM
AK4Wheeler's Avatar
AK4Wheeler
I just bought this truck and have a couple issues, this one bothers me the most.
The idiotlight stays on all the time, obviously cause theres a problem.
When I hit the brakes the rear lock up. It just snowed today so that might get interesting driving when I need my brakes.
Is there a number of things it could be or maybe one??
The previous owner told me that it happened once before and that the piston needs to be realigned....
He and I have no idea what the means. Any ideas??
Thanks
Old Oct 23, 2004 | 08:35 PM
andym's Avatar
andym
Take it to a shop and have the ABS codes pulled, then go from there. My guess is that it's the ABS module, but there's no way to know for sure.
Old Oct 23, 2004 | 09:45 PM
Crazz's Avatar
Crazz
what year truck is this ? that would help. and you should be able to pull your own abs codes.
Old Oct 24, 2004 | 03:59 AM
AK4Wheeler's Avatar
AK4Wheeler
sorry,
Its a 1990 f250 4x4 with 302 manual trans.
Old Oct 24, 2004 | 09:15 AM
low-side's Avatar
low-side
It's a pretty simple system and a repair manual should tell you how to pull abs codes w/o a scanner. Unequal pressure between the wheels or a bad hose acting as a 1-way valve can trigger it as well as speed sensor issues.
