AOD Question
Old Oct 22, 2004 | 07:38 PM
oldschool63's Avatar
oldschool63
AOD Question
I have a 65 F100 with a 300 in it and would like to put the AOD trans behind it and get rid of the granny 4 speed I'm using now. I've read most of the other posts about this swap and everyone seems to be going to at least a 2 barrel carb to do this. My question is, can i do this using the stock 1 barrel? (not the 1100 but the carter YF) I do know ford put carbs on the 300's up into the mid 80's but did those engines use the overdrive trans or just manuals? I figure if the emission carbs had the tv cable attaching point it would be a simple matter of swapping the throttle shaft into an earlier carb. Any insight about this would be greatly appreciated.
Old Oct 23, 2004 | 12:49 AM
Thudpucker's Avatar
Thudpucker
OldSchool
When I researched this question, I went to a good transmission shop.
I found some interesting things about that AOD Transmission.
They happend to have one out on the bench, all apart, and he showed me a weak spot in the center of the Transmission.
It looked like a "no abuse" policy would be in order there.
What scared me was a warning:
There's a Cable from the Throttle to the Transmission.
That has to be absolutly correct or you'll do some serious damage to the Transmission immediatly on power up of the engine.
The last concern I had was the Flex plate and Torque converter to match a 300 to an AOD.
I never have seen one. I knew the 300 was connected to a C-4 and even the C-6, but who knows where to look and which parts will interchange?
Througout the years, I've often wondered why Ford didn't make a 300/AOD combination in the F-100 or even the F-150?
Old Oct 23, 2004 | 05:35 AM
oldschool63
ah but they did. only it was behind the fuel injected models. i would prefer not to go that route.also, there have been several excelent articles in a couple of the hot rod magazines about adjusting the cable on these trans.
Old Oct 23, 2004 | 07:10 AM
Yakk's Avatar
Yakk
Ford made a 300/AOD combo but only till the E4OD replaced it.
Though 5.0 EFI's still had the AOD available as a lower cost Overdrive option.
The flexplate bares one difference from the C-6 flexplate, the depth for the Torque converter mounting is different.
Otherwise it bolts up.
There is a company on the net called www.bulkpart.com
They have AOD/300 flexplates for uber cheap, prolly cause demand is very low being a rare combo.
P/N F224AC $17.16
I paid $50+ locally.
-J-R-
Old Oct 23, 2004 | 08:45 PM
javi2001's Avatar
javi2001
I did that upgrade 3 years ago and it works nice with my stock engine BUT:
You have to change rear axel to at least 46X13 or 3.55 and use tires 235/7.5R15 or your engine will fade as soon as tranny apply overdrive.
Old Oct 23, 2004 | 08:52 PM
oldschool63
Details please! did you use the stock carb? were there any other minor details that you had to work out? thanks in advance!
Old Oct 24, 2004 | 12:14 AM
Intillzah's Avatar
Intillzah
The TV cable is the one thing that gives the AOD a bad rap in trucks, It's adjustments are critical. But not out of the realm of the home mechanic. And as for the internals, just stuff in the internal gears and clutch packs out of a AOD-E. That's what I'm thinking about doing, it's the same case.
I just need to get together the rest of the stuff for the swap. I am going to a AOD from a Mazda 5 speed in my 93.
Old Oct 26, 2004 | 05:31 PM
javi2001's Avatar
javi2001
Please email me home, I had all info there. Unfortunatelly I had no internet acces at home, just email.
RFAgrasshopper
May 25, 2012 01:25 AM
Lumpy78
May 4, 2010 11:25 PM
John 300
Oct 13, 2009 07:36 PM
John 300
Oct 13, 2009 10:52 AM
gtuttle
20
May 14, 2009 12:51 PM
