Which wt motor oil?
Old Oct 22, 2004 | 03:50 PM
xspeedyx's Avatar
xspeedyx
Question Which wt motor oil?
Hey what is everybody using for oil? Currently running mobil 1 0-20wt oil. But with so many choices like 0-20,0-30,5-30,10-30,5-40,15-50? Frankly I'm confused. I know the manual says 5-20 but it just seems to thin and in the Texas heat I am concerned with wear protection. Thanks XspeedyX. P.S. I guess I'M just used to old fashond 30wt oil.
Old Oct 22, 2004 | 03:54 PM
mountravlr's Avatar
mountravlr
Check Out the UOA Results
From the UOA results on Motrcraft 5W-30, your assumptions may be incorrect as to that particular oil being "too thin" in Texas summer heat.
Old Oct 22, 2004 | 03:56 PM
mountravlr's Avatar
mountravlr
Please excuse the above typo: it should read 5W-20.
Old Oct 22, 2004 | 04:17 PM
xspeedyx's Avatar
xspeedyx
What are the uoa results and how do find them? Thanks
Old Oct 22, 2004 | 04:40 PM
mountravlr's Avatar
mountravlr
http://theoildrop.server101.com/ubb/...?ubb=forum;f=3 This is at bobistheoilguy.com There are many UOA resolts posted there.
Old Oct 22, 2004 | 05:57 PM
Landyot's Avatar
Landyot
5W-20 was a last-ditch effort to gain a smidgen more MPG. If you look at the spec's for Excursions in other countries (where 5W-20 is nearly impossible to find), you'll see 10W-30 is the standard. 5W-20 may be good for MPG, but I want my beast to last awhile. I use 10W-30.
Old Oct 23, 2004 | 06:09 AM
xspeedyx's Avatar
xspeedyx
I would have to agree with you on that one.
