wheres the oil going?
Old Oct 21, 2004 | 10:16 PM
1984 f-250's Avatar
1984 f-250
Question wheres the oil going?
i have a 1992 explorer that keeps using oil but it does not smoke or leak. I add a little oil every 5 days or so to keep it topped off. has anyone else had this problem or any ideas?
Old Oct 21, 2004 | 11:43 PM
mrshorty's Avatar
mrshorty
Oil consumption is one possible symptom of loose lower intake manifold bolts. Fairly common to these engines. It can also lead to coolant loss and pinging. It's common enough that I recommend that a person periodically tighten those bolts as a matter of preventive maintenance. Not sure if it's the cause of your oil loss, but it was my first idea.
Old Oct 22, 2004 | 10:22 AM
jclj2003's Avatar
jclj2003
mine did the same thing it was the lower intake gasket it took me about 3-4 hours the replace it but now my truck hardly eats oil like 1/2 quart every 3k
Old Oct 22, 2004 | 11:04 AM
gibsonj's Avatar
gibsonj
How much oil is it using? How many miles on the engine? Some oil will slide past the valve stem seals, and vaporize. If it turns out to be valve-related, you have to decide cost of repair vs. how much oil consumed vs. age of the power train vs. how long you intend to keep it.
Old Oct 22, 2004 | 11:37 AM
1984 f-250's Avatar
1984 f-250
i have 210,000 miles on it and it uses about half a quart every week
Onus
Oct 31, 2011 03:17 PM
johnboggs21
Oct 31, 2009 11:18 AM
LonnieD
1978 - 1996 Big Bronco
Feb 28, 2006 07:50 PM
monoman
Oil & Lubrication
Oct 12, 2005 11:22 AM
