Carb Problems??? Fuel Pump? IDK!
hey guys, my truck (87' F150 XL 351W 4bbl) is having some issues. I pump the pedal 3 times and it kicks over fine (when its cold), but then when I stomp on the gas real quick to take it off choke, it just starts to sputter and die. Now, mind ya, I'm low on gas (5 gallons at a time.... bad brakes that I'm working on...I start it every day...
). So any ideas? Also, does this thing have an in tank fuel pump or not? I get conflicting info. other people tell me because it's carbed that it doesn't and others tell me it does. Can anyone clarify?latah!
Pat
But any ways It has a fuel pump on the block I just wanted to know if there was one in the tank.
I think the pump is ok. it filled an 8 oz. glass coke bottle real quick...didn't want the gas eatin' a plastic bottle...
It only starts to die when I stomp the pedal to kick the choke off. Then it acts like it's starving for fuel. I noticed there was something called a throttle kicker on the carb. That, along with all of the other emissions junk is disconnected and in a box in the shed. I know that regular carbs without the emissions crap doesn't have a throttle kicker. Or at least I haven't see one with one. The only vaccum to the carb is the vaccum advance line. All other ports are plugged.
I just can't figure this out...my truck bogs and dies when I take it off choke, my sleds did the same thing, my weedwacker...but the last 2 I have fixed...I just need this hoe to get straightened out and start running like something close to a vehicle...
I"M ALWAYS PLAGUED WITH CARB PROBLEMS!!!!Thanks though any other ideas?
(uck! 283 bucks...) This thing is being such a "hoe" to me. It was replaced in 98', then had the engine replaced 2 years later, and 2 years after that, it sat on cape cod in the salt air for 4 years. When I got my greasy little paws on it, the truck had a rusted & stuck throttle linkage (which I have fixed) and a bad backfire, which was a result of a bad dizzy cap & rotor, and some other misc. stuff. what's this power valve stuff? Is it like a power jet on a snowmobile carb (mikuni VM series) where it bypasses the main jet and sends mucho grande amounts of fuel into the cyl.?
