2004 F150 ext cab ---> stereo help
I have a 2004 f150 extended cab and have 2 JL audio w0 subs and a kenwood 600watt amp hooked to the stock speakers and headunit.
I installed everything and the subs face downward into the floor and it's not very loud at all. The box I bought off ebay fits nicely under the back seat and is as big as I can make it.
Is there something else that would be making it sound bad? Are the stock speakers that bad? I read something online that as you turn the volume up --the system cuts bass to keep sound quality..if that is true am I wasting sound w/ the stock speakers? Let me know!
Have you turned up the gain on your amp? That should make the subs louder. Then, you won't have to turn up the head unit as much to get more bass. Regarding the speakers, they really aren't that bad. BUT, the head unit does cut bass as the volume is turned up in order to keep distortion at a minimum. I'm guessing your amp is just going to the subs. If more gain doesn't help, you may want to think about a second amp to drive some new speakers.
Hope this helps!
Hope this helps!
Without actually getting into your truck and seeing what the heck is going on, I would say that the subs could be wired out of phase. This is when one sub is wired right - + wire to + terminal and - wire to - terminal; and then the other one has the + wire to - terminal and - wire to + terminal. This effectively has the 2 subs cancel each other out. Hence no bass.
6ohman2004
15
02-06-2014 12:37 PM
Patatoe1
09-28-2005 11:05 PM
First Ford Truck
10-11-2003 11:40 AM
