quick door speaker connection question!
Old Feb 5, 2014 | 03:28 PM
6ohman2004's Avatar
6ohman2004
Hello all! So I've completely upgraded my sounds system in my 79 f150 single cab with aftermarket deck, door speakers, rear speakers, tweeters, rear sub, amp, and
Running all the wiring for this I thought I had it nailed.
But 2 months into the system being installed I have a bad connection at the door jam going to the door speaker and tweeter. What is the best way to finish this connection so it doesn't get smashed in the Jam?
Old Feb 5, 2014 | 03:41 PM
HIO Silver's Avatar
HIO Silver
Jamb tacs by Painless?
Old Feb 5, 2014 | 03:49 PM
6ohman2004's Avatar
6ohman2004
Hmm those would be interesting, I've never heard of them. Have you used them before?
Old Feb 5, 2014 | 06:05 PM
fmc400's Avatar
fmc400
MSEE
As long as you have a reasonable length of conduit, it's not a problem. Here's mine (trouble-free for years):
Old Feb 5, 2014 | 06:58 PM
HIO Silver's Avatar
HIO Silver
Nope.. just suggestion.
But I would think your installation would have used grommets. Try to leave one tight around the wires and the other grommet loose so the wrapped/sheathed bundle can slide in and out freely.
Old Feb 5, 2014 | 07:09 PM
JWC 3's Avatar
JWC 3
Grommets and wire loom work great . You just need to allow for flex and travel with your lengths .
Old Feb 5, 2014 | 09:49 PM
6ohman2004's Avatar
6ohman2004
I didn't have grommets, just wrapped well with electrical tape. But it didn't get cut from the metal holes in the door or cab. It seemed to pinch and fold the wire in the "slack" I left until the tape, wire sheath and finally the wire broke.
Old Feb 5, 2014 | 09:50 PM
6ohman2004's Avatar
6ohman2004
I'm wondering if the tape made it to rigid To flex so it just broke
Old Feb 5, 2014 | 11:17 PM
Ordnance's Avatar
Ordnance
I couldn't find grommets when i did my door speaker install, so I made my own by taking rubber vacuum line, splitting it, and gorilla gluing it in place in the door jamb. It works, but i drilled my holes about 6" offset vertically, so it naturally had enough slack to open and close properly, however i feel it will get pinched in the door jamb switch. If i had to do it again, I'd move the holes below that.
Old Feb 5, 2014 | 11:34 PM
6ohman2004's Avatar
6ohman2004
I'm gonna have to find something like that too make it work. Good tip abut the holes though, mine are the same height so it folds
Old Feb 6, 2014 | 10:28 AM
76F15OSuper's Avatar
76F15OSuper
I used fuel line as a wire loum only afixed one side solid so the other side would slide in and out of the door as it opened and closed so there would not a pinch point.
Full open there was about 1/2" of hose inside the door. and the wires had slack in them to move.
Don't have that vehicle any more and don't have a pic of what I did.
Old Feb 6, 2014 | 11:24 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Hit the local JY for this harness....here are your door hole drilling measurements. The last 2 pics are the cab measurements, cab hole is measured from the top of the door hinge.
And an alternate method.
Old Feb 6, 2014 | 12:02 PM
6ohman2004's Avatar
6ohman2004
I'm excited to try some of these ideas! Thanks guys and that original grommet looks like it would do well. I'll definitely be looking for that part of the harness
Old Feb 6, 2014 | 12:10 PM
77&79F250's Avatar
77&79F250
Those detailed pic and that harness came out of a 79 bronco XLT.
F150, F250 and 78/79 Bronco pretty much all the same on the inside. TO A DEGREE, I do not want to start no whizzing match with that statement!
The guy is just looking for a OEM stereo wiring harness.
Old Feb 6, 2014 | 12:22 PM
6ohman2004's Avatar
6ohman2004
Yes, thank you for the pics! Makes things way easier
