Engine Stalling
Old Oct 21, 2004 | 05:23 PM
nuts4hotwheels's Avatar
nuts4hotwheels
Question Engine Stalling
I have a 1986 F150- 302 EFI and it intermittently stalls and will not start for a few minutes. It did it once when I came to a stop and once it did it at about 60 mph. Does anybody know what could be wrong? , or where to look first? Any help will be greatly appreciated.
Thanks,
Nuts4Hotwheels
Old Oct 21, 2004 | 06:25 PM
Lee Lichterman's Avatar
Lee Lichterman
A code check would help probably. Coils often quit only when hot at first. It could be many things, loose electrical connection just about anywhere.
Does switching tanks help? Any idea if it is electrical (spark) or fuel?
I would run a code check and if nothing, next time it does it, check for spark. Note if it seems to only do it when engine is hot etc. The more symptoms the better so we have more to work with.
Good Luck,
Lee
Old Oct 22, 2004 | 06:19 AM
nuts4hotwheels
Every time that it has occurred I was only about 5-10 minutes from home. So, it didn't heat up a whole lot.
Old Oct 22, 2004 | 08:54 AM
RR4E's Avatar
RR4E
Try cracking the gas cap loose on the fuel tank, and see if it fires back up. If it does, likely a fuel pump or plugged air intake filter for the fuel tank. Fuel filter could also cause this problem.
Old Oct 22, 2004 | 03:37 PM
Lee Lichterman
My first guess would be a coil. They heat up faster than the engine since they are firing thousands of times in a just a few minutes but I would try to run a code check first.Basic scanners are cheap, only about $30 or so at WMT.
Lee
Old Oct 22, 2004 | 03:52 PM
lmadore's Avatar
lmadore
Check the TFI module when this happens.
When going bad some of them will cause similar symtoms.
Eventually it will fail completely.
