oil pressure
Old Nov 16, 2002 | 05:01 PM
beerguy's Avatar
beerguy
oil pressure
I was wondering if someone knew why my oil pressure drops all the way down when I hit a red light or if Im stoped for a while. As soon as I start to accelerate the pressure starts to go back up.I also have a real bad clanking noise all the time. I've been told that it maybe my lifters. If anyone has another guess please get back to me.:-staun
Old Nov 16, 2002 | 06:23 PM
Ken00's Avatar
Ken00
oil pressure
When the rpms are slower the oil pump turns slower so that is why your pressure drops when you are stopped at a light. Low oil pressure will cause the valve noise due to the lack of oil at the top end, the top end is at the end of the oiling system. A bad oil pump, clogged pick-up screen or worn cam bearings are common causes. I would put a real gauge on it to determine the oil pressure, the stock gauges are not accurate. You didn't say what engine or miles but the 2.9L is known for a noisy top end.
Old Nov 17, 2002 | 02:17 AM
tonyevans69's Avatar
tonyevans69
oil pressure
