351 460 swap????
Old Oct 21, 2004 | 09:10 AM
dekhaf's Avatar
dekhaf
351 460 swap????
hello ford lovers. i am the proud new owner of a 1978 f150 4x4.the question i have to ask is what limitations i might encounter on dropping a 460 out of a 1977 trailor special into my 4x4 in place of my 351 m. also i would like 2 know where the location of the part #s are for the rear end front end and transmission are so i can figure out what parts ive got because i dont have the original doors to get the #s from i believe both of the drive trains are stock for the most part
any help with building my dream 4x4 will be greatly appreciated
Old Oct 21, 2004 | 04:58 PM
66f14evr's Avatar
66f14evr
first thing to start looking for is a rear sump oilpan then you have to takeoffthe engine craddles from the frame and buy after market ones I"m sure that one of the site sponsors sell these then its a matter of exhaust
Old Oct 21, 2004 | 05:10 PM
74 F100 351m's Avatar
74 F100 351m
Why put a nother 175#s on the front end? just build the M.
Old Oct 22, 2004 | 05:22 AM
Colo79Ford's Avatar
Colo79Ford
Im with 74 on this one....build the 351 up. Youll be happier, and it will weigh less. Read some of the posts here to see how you can build it up.
---JOHN
Old Oct 24, 2004 | 01:11 PM
dekhaf's Avatar
dekhaf
the 351 is already pimped it doesnt run ive got the 460 already and i was thinking i could use the springs from the donor truck a trailor special to bring the front end back to ride hight. ive found a lot more sites on this mod and they are saying that the only thing needed is the rear sump and the engine mounts from l@l adn that it might be wise to look into fender well exit exhaust
what about putting a 302 from a grand marquis in instead until i can find another good running motor instead can i interchange the bell housings to make the bolt pattern work??
Old Oct 24, 2004 | 04:17 PM
66f14evr's Avatar
66f14evr
one thing i have found about this site is that 99.9 percent of what the senior people on this site are awsome with the info that they tell you .it makes it hard to make a choice on wether to do such a swap so one thing i found is let your wallet make the choice
Old Oct 24, 2004 | 06:45 PM
74 F100 351m
The frount spings are the same for the 351m and 460. Look at the pictures of my 351M.
RHO
25
Mar 5, 2012 12:58 PM
jamie_lind2006
Engine Swaps
Feb 5, 2007 08:13 PM
72RADFORD72
Engine Swaps
25
Dec 17, 2006 09:17 PM
orangeford
Oct 27, 2001 06:47 PM
